Evo 5 no crank. Starter clicking fast
Old Aug 24, 2023 | 06:19 PM
evo5boi's Avatar
Hello everyone, I’ve recently finished putting my Evo 5 back together and everything was good smooth until this morning. I’m having a issue where I go to start the car and all I hear is rapid fast clicking from the starter I went out and got a new start and new battery but still having the issue and was seeing if anyone would’ve able to help out guiding me in the right direction. I’ve checked all the wires, relays and fuses and everything seems fine. I’ve attached a video of the issue I’m having.
File Type: mov
Old Aug 24, 2023 | 07:49 PM
ViciousLSD's Avatar
try supplying batt voltage to the starter wire, basically bypassing the ignition and fuses/relay. what does your starter relay look like? on my evo9, pin 5 of this relay is to the starter (just as an example since yours might be very different)
or just use a new wire to the starter
if it cranks fast(faster than normal) then you could have switching issues
Old Aug 24, 2023 | 07:56 PM
evo5boi's Avatar
I was just checking over and on the Evo 5 the wire goes from the ignition switch to the starter solenoid [relay] with no relays inbetween
Old Aug 24, 2023 | 08:34 PM
ViciousLSD's Avatar
right, so its similar. on my car that 12v supply to the relay is weak after passing thru all the old connections, ignition switch etc. thats why I rewired my relay in that pic
Old Aug 24, 2023 | 08:38 PM
ViciousLSD's Avatar
on ours the relay is really not a relay its just to require you to step on the clutch to start
so screw that
Old Aug 24, 2023 | 10:06 PM
evo5boi's Avatar
I see, so I just quickly disconnected the small wire that goes to the starter and wired up a wire that goes from the positive terminal to the starter solenoid but it just does the same thing and click fast rapidly
Old Aug 25, 2023 | 06:47 AM
ViciousLSD's Avatar
yeah. in fact i still have that extra wire near my battery terminal so I can start without going inside the car.
I had this also in the beginning
imissmyhonda
15
Oct 1, 2018 10:30 AM
danfalcas
Mar 3, 2015 12:08 PM
ihatemyusername
Sep 11, 2014 08:56 AM
NSDQ
Jul 15, 2014 07:03 AM
nekkidlad
Oct 31, 2011 05:16 AM
