Need Help!
Old Dec 28, 2024 | 04:37 PM
Pedro26's Avatar
Need Help!
I’m new to the Evo Platform, last week I was heading to work didn’t hear any noise at all from the car came to a stop at a stop light and as soon as I crossed the intersection the rear wheels locked up and couldn’t move… I waited a few minutes and decided to drive to a gas station to get out the road and it happened again…. So I slowly drove out of the road ( 5mph or less ) sense I got towed home and I changed out the rear diff fluid but didn’t see no metal shaving or glittery gear oil, replaced the fluid… 2nd thing I’ve tried was lifting up the rear end and free spinning the rear wheels and nothing happens… so I put the car on floor and decided to just move the car back and forth again it’s deciding to lock up the wheels in either direction so if it locks up going forward I have to reverse it to free it vis versa…. Don’t know if it’s a wheel bearing, ring pinion, parking brake system, axle bearing…TIA!
Old Dec 29, 2024 | 01:43 AM
ViciousLSD's Avatar
front diff. drain it then remove the rectangular inspection cover. you might see something like this
Old Dec 29, 2024 | 09:06 AM
RallySport9's Avatar
^ I second that, same exact thing happened when my tcase blew up. Ring gear was all chewed up and awd system completely locked it was absolute carnage inside.
Old Dec 29, 2024 | 04:37 PM
Pedro26's Avatar
I’m gonna have to check that out tomorrow and I’ll get with you guys tomorrow on that. If I don’t see anything I think I’ll just end up removing the rear differential and opening it and checking the bearings in their just don’t want to purchase everything with out knowing the problem
Old Jan 1, 2025 | 04:49 AM
RhettButler's Avatar
Any update on it?
Spoiler
Old Jan 1, 2025 | 03:25 PM
Pedro26's Avatar
I didn’t find that much damage but this is what I noticed from the that cover plate
The pinion gear looks pretty sharp but don’t know if that’s how they are
Old Jan 1, 2025 | 05:09 PM
I can see what look like metal shavings and the oil is a muddy color and yea the ring and pinion gears look pretty chewed up...not looking good to me.
Old Jan 1, 2025 | 08:35 PM
ViciousLSD's Avatar
mine got chewed up because I kept trying to drive the car to get it off track. I also got pulled away back to the paddock and i heard crunch metal a several times.
Cian Mcloughlin
Apr 8, 2016 12:38 PM
cmspaz
May 11, 2014 08:53 PM
K2_Evo
Nov 2, 2013 02:07 PM
ICE888
18
Apr 20, 2007 08:12 PM
Ultor
10
Jan 10, 2005 01:23 PM
