Where can I get the battery relocation connectors from?
Old Jul 29, 2004 | 11:11 AM
schleppy's Avatar
I'm about to get the battery relocation wiring kit from summit racing (the 2ga wiring kit, positive and negative). All I need to find now is the little metal connector that joins the new remote battery terminal to the positive terminal that is still under the hood.
Also, to those that have relocated your battery, where did you connect your ground cable? Do you even have to connect it to something, or can you just tuck it away?
Thanks!
-Sean
Old Jul 29, 2004 | 02:34 PM
areet's Avatar
Autozone 2 gauge lugs, I think they're like 2 bucks. I connected the ground cable to one of the bolts that hold the trunk latches.
Old Jul 30, 2004 | 04:37 AM
schleppy's Avatar
Ok cool, that takes care of the ground cable!
Now, what should I do about joining the two cables under the hood? I guess it would have to be something with two posts on it that I could just slip each of the terminals on to.. I'm not really sure.
Bump!
Old Jul 30, 2004 | 09:40 AM
areet's Avatar
Remove the battery terminal from it, open it up to get the bolt (or just use a nut and bolt), put the lug on the end, and tighten it down.
Old Jul 30, 2004 | 10:26 AM
spyderx's Avatar
where did you guys pick up a battery relocator kit from?
Old Jul 30, 2004 | 10:32 AM
livelyjay's Avatar
Summit Racing:
http://store.summitracing.com/partde...N=120%20307185
Old Jul 30, 2004 | 10:34 AM
livelyjay's Avatar
Think you could do a write up for the relocation procedure?
Old Jul 30, 2004 | 11:06 AM
areet's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=89242
Old Jul 30, 2004 | 11:23 AM
livelyjay's Avatar
Nice writeup. Looking at that (since I haven't taken off the positive terminal on my car yet) makes me realize this is going to be a lot easier than I had first thought (and not to mention cheaper). That definitely eliminates the need for a distribution block in the engine compartment, and keeps it possible to jump start the car from the front.
Old Jul 30, 2004 | 11:49 AM
areet's Avatar
Heh, the longest, most time consuming part was running 2 gauge wire under interior panels. The one on the front passenger door doesn't really click anymore.
Old Jul 30, 2004 | 12:37 PM
spyderx's Avatar
do you recommend 2 gauge wire, can it be thinner?
also, what you do w/ your wing, looking for a spoiler for my red RS...
Old Jul 30, 2004 | 12:54 PM
livelyjay's Avatar
For an EVO I wouldn't go any less than 2 gauge, but the real determining factor is how many amps are being drawn when you start up the car. If you search online you can find out how much amperage different gauge wire can carry. Knowing how much your car pulls when you start it will help you determine what gauge you need.
http://www.powerstream.com/Wire_Size.htm
Old Sep 6, 2004 | 06:34 PM
schleppy's Avatar
I'm still looking for something to join the stock positive terminal to my new cable I have run back... Any other ideas?
Old Sep 6, 2004 | 06:41 PM
BMan's Avatar
Hook it directly to where your + hooks now. Don't use the existing + cable under the hood. That is what I always do.
guyver858
Aug 15, 2015 03:30 PM
amscrazy
Jan 30, 2008 11:33 AM
bigric09
Jan 20, 2008 05:14 PM
urbanknight
Jan 17, 2007 09:42 PM
propellerhead
Oct 15, 2004 07:23 PM
