Oil Pressure and Temp Gauge Install
Old Aug 29, 2005 | 06:53 PM
  #46
webguy330i's Avatar
Yeah the sensors are PT not NPT, unless you ordered them with the NPT fittings. They are optional per the operator's manual.
Old Aug 29, 2005 | 06:56 PM
  #47
webguy330i's Avatar
Oh and regarding the NPT fittings, prostreetonline.com stocks them! I just ordered my EGT fitting.
Old Dec 20, 2005 | 11:26 AM
  #48
li1p1aya's Avatar
For those of you concern with mixing different threadings (BSPT w/ NPT), the link below does a good job of explaining the consequences.
http://www.colder.com/Downloads/NPT.pdf
The reducer conversion (BSPT to NPT) can be found in most local plumbing shops for only a few bucks. All the fittings at Home Depot are only NPT also.
Old Dec 21, 2005 | 04:37 PM
  #49
en1gma19's Avatar
How the f*ck did you guys get those hex bolts out?
I tried with an allen wrench forever and just ended up stripping one of the bolts. Is there a secret?
Old Dec 21, 2005 | 07:01 PM
  #50
webguy330i's Avatar
Originally Posted by webguy330i
OK guys I just installed my defi bf oil pressure gauge this weekend. My sensor had a 1/4 adapter on the end, so it fit perfectly into the hex bolt which is right above the oil filter (there are two of them, I used the one CLOSER to the filter).
FYI if you are going to attempt this, do yourself a favor and purchase an 8mm hex socket for your 3/8" ratchet. That hex bolt is a total b!tch to remove. Don't forget to teflon tape your adapter/sensor threads.
re: hex bolt removal
Old Dec 22, 2005 | 03:26 AM
  #51
WarmPepsi's Avatar
i just had the right size, you put it in the long way, and use an adjustable wrench to generate force off the small end, wasn't really that hard.
Old Dec 22, 2005 | 07:28 AM
  #52
bolsen's Avatar
Yea, those hex bolts are a *****. You HAVE to make sure it's the right size tool.
Old Dec 23, 2005 | 06:02 AM
  #53
sillypuddy's Avatar
ok
i am back.. long time away
1. i have the greddy block and have no problems with it.. the only thing you have to remember is that you can no longer use generic filters.. you MUST USE THE SHORT MITSUBISHI FILTERS.. if you go to the dealer, he has two styles, a thin and tall one, you don't want that.. he has a fat and short one you want that..
the fat and short one will clear your splash guard.. if you still rip it off the engine, somethign is wrong wih your driving..
2. i went through all the hex bolts, nuts, etc.. under the engine.. unless your sender is very very narrow, there is no way you will be able to mount it on any of those holes AND still get an accurate reading.. i chose the filter mount location because oil is always circulating there..
i am installing an oil cooler with a bypass kit, so i will be moving the whole mess up to the firewall.. just FYI
-joe
Old Dec 23, 2005 | 06:13 AM
  #54
mump's Avatar
Originally Posted by sillypuddy
ok
i used the block too and had a generic filter on, it hung passed the plastic shield and my cusco bars... very scary. i took my car into mitsu for warranty work (brakes) and the guy told me when I was picking up my car "I like your new gauges, took the time to a small filter so it will tuck up under the car. I know you like to do your own work so we will sell you the little ones at our cost just so you are safe." So I went over and bought 10 of them.
Old Dec 23, 2005 | 07:23 AM
  #55
sillypuddy's Avatar
-joe
Old Dec 23, 2005 | 11:31 AM
  #56
Jakeg97's Avatar
thats cool
Old Jan 21, 2006 | 05:08 PM
  #57
Aikido's Avatar
signed in
Old Jan 21, 2006 | 05:18 PM
  #58
04 evo's Avatar
Correct me if I am wrong, but don't they say not to use teflon tape when installing the oil pressure sender to ensure a proper ground????
Old Jan 21, 2006 | 06:04 PM
  #59
webguy330i's Avatar
iirc my little defi booklet said teflon tape was required on that one.
edit: yeup http://www.defi-shop.com/product/bf/bf_manual.html
Old Feb 3, 2006 | 02:38 PM
  #60
alan0108's Avatar
Anyone knows the part number of that short Mitsubishi oil filter?
