Oil Pressure and Temp Gauge Install
Old May 19, 2006 | 04:15 AM
  #121
MIevo8MR's Avatar
Originally Posted by S14Swap240sx
so it looks like pulling that 8mm hex out by the oil filter seems to be a safe bet, but what adapter have people been using? what works what doesnt? im not worried about oil temp, just more concerned on oil pressure, when its time for oil temp its gonna be time for a oil cooler and oil filter relocation kit neways
I've had my Defi gauges hooked up for almost a year now. No problems so far. I'm using the adapter from 42draftdesigns.
http://www.42draftdesigns.com/product/42902.htm
Old May 19, 2006 | 12:09 PM
  #122
S14Swap240sx's Avatar
is there room to t off that adapter instead of using a 45 degree adapter to install oil pressure and temp?
i kno these questions are getting repetative, i just dont have the time to look under the car for my self.
Old May 19, 2006 | 02:09 PM
  #123
RRRS's Avatar
there's 2 hex plugs, get 2 adaptors from 42draft and you're good to go
Old May 19, 2006 | 02:12 PM
  #124
MIevo8MR's Avatar
+1
But I think you only need one of the elbows. The other hex plug is a straight shot out. The other hex plug you'll need the elbow to get around the oil filter. Someone correct me if I'm wrong.
Old Jul 6, 2006 | 07:02 AM
  #125
xtnct's Avatar
On my 9, I installed the sender on the side of head as Invoice EVO did (see pics below) as it was the easiest to get to. Had it on the car for about a month now.
But, this may not be the best spot on the 9. Does the 9 have some restrictions or valves up there that maintain the pressure at a constant levels? Reason I ask is that my readings to not fluctuate like other cars I have had (such as increase in pressure as rpm's & WOT are increased).
My Evo 9 readings are as follows:
- After starting the car (cold), it will read about 60 psi for 2 mins
- It drops down to about 25-30ish psi in the next 5 mins or so and remains constant at that level no matter what kind of rpm or throttle position is used.
- At idle, it drops to about 0-5psi or so.
- Prolonged periods (10-15mins or more) of constant high rpm at WOT, pressure makes its way from the constant 25psi reading to about that of idle (I'm guessing the increased oil temps get the oil really thin)
There is nothing wrong with the car and the sender/gauge appears to function properly.
Any thoughts on this?
Originally Posted by Invoice EVO
Old Jul 6, 2006 | 01:37 PM
  #126
BOBix's Avatar
Been reading here seems there is no real deal here.... everyone seems to have points which is nice to here...... But i think i was looking for someone whos got a soild answer about what is best and why!! Anybody with more cool info!
Old Jul 6, 2006 | 02:05 PM
  #127
bolsen's Avatar
There is no better spot. Pick one and be done with it.
The reason you have a gauge is to make sure it doesn't say 0. If it hits 0 you're in trouble.
Pick a spot and start worring about what beer you're going to buy while doing the install.
Old Jul 6, 2006 | 03:17 PM
  #128
nils's Avatar
lol... that is right.. i's all relative mang.. is all relative.... find your comfort zone and run with it!!
n
Old Jul 29, 2006 | 04:48 AM
  #129
kmcconn9's Avatar
i guess you have to wonder what is more likley to go out...the motor or the oil pump..and that will determine which spot you use..
I think close to the stock sender location is best imo...
Old Jul 29, 2006 | 04:55 AM
  #130
kmcconn9's Avatar
Are there any gauges that have the warning feature but do not require the use of a control box?
Old Jul 29, 2006 | 05:19 PM
  #131
WarmPepsi's Avatar
my stock oil temp gauge went nuts today.
It PEGGED past 150, outta nowhere, so i stopped, slapped the gauge a few times, with no result.
Felt both my oil cooler lines, and they weren't THAT hot. Let the car sit for 25-30 minutes, and it was still pegged, i still had plenty of oil pressure and plenty of oil.
Then during the next session, it started working again, then again, went nuts-o.
Old Jul 29, 2006 | 05:22 PM
  #132
kmcconn9's Avatar
weird.....
Old Aug 1, 2006 | 07:45 PM
  #133
bernardo's Avatar
Nevermind...
Old Aug 2, 2006 | 05:46 PM
  #134
bernardo's Avatar
One more question, in reference to tapping the head for the oil pressure sensor, Invoice Evo (around post #94) used this spot on the head.
There are three "taps" in that area, all in a row, about 2" apart from each other. Is any of the 3 spots ok to use? (the below pic only shows the middle of the three) It looks like the middle one (circled in the pic) is the most accessible one, is that the one to use? Thanks
Old Aug 2, 2006 | 05:57 PM
  #135
kmcconn9's Avatar
Thats interesting...the 8's dont have the extra "cam plate??" to the right of where your red circle is...
