Installation of 10.5 hotside
Does anyone have a walk through for installing '05 compressor housing and turbine housing onto an '03 or '04?
Thank you.
Thank you.
This is basically easy to do. IF you work on cars it's not too bad. YOu need to get off the 4 bolts and a band clamp. The hard part is getting the 4 bolts off without messing them up. Keep in mind that this is no job for a novice person. I have swapped a dozen turbos on eclipses and this is the same way .
Where's warrtalon...search and you find this ya lazy bastard:
https://www.evolutionm.net/forums/sh...d.php?t=132695
