Installing CF A pillar Gauge Pod
Old Sep 18, 2005 | 03:10 PM
RevvDon's Avatar
I have had my dealer install the CF A pillars I purchased from Evomoto. The 2 sided tape they use keeps coming loose in the heat under the weight of the gauges. What should I be using to attach the Cf to the stock A pillar? BTW, the fit of the CF cover is pretty bad.
Old Sep 19, 2005 | 07:19 AM
RevvDon's Avatar
bump
Old Sep 19, 2005 | 08:20 AM
J8dailo's Avatar
i had those..i just screwed it on the stock pillars
Old Sep 19, 2005 | 10:29 AM
RevvDon's Avatar
Thanks. I'll look into that. The tech at the dealership said that Autometer makes some kind of pin/screw for pods.
Old Sep 19, 2005 | 03:03 PM
r3z0nate's Avatar
Whats the brand of those A-Pillars? I thought they were direct replacement, not covers.
Old Sep 19, 2005 | 04:00 PM
virtex's Avatar
You know I was thinkin the same thing
Old Sep 19, 2005 | 04:10 PM
r3z0nate's Avatar
I find it hard enough putting the stock ones back on, let alone adding material to them.
Old Sep 19, 2005 | 07:23 PM
RevvDon's Avatar
Actually I'm not sure who manufactures them but I purchased them from evomoto.com
http://www.evomoto.com/product_info....products_id=80
They are described as covers not replacements. They did not come with any detailed installation instructions. I also have the B-pillars and they look nd fit great
Old Sep 25, 2005 | 08:45 AM
mr0072003's Avatar
I had the exact same issue, and it drove me crazy...it will eventually start happening to the passenger side too, what I had to do was screw screws into them and problem was solved...I Will try and get pics for you later...
Old Sep 27, 2005 | 07:17 PM
RevvDon's Avatar
Thanks. I'd be interested in seeing the pix. What kind of screws and where?
Old Jan 10, 2006 | 12:49 PM
ROCK's Avatar
USe blackhead rivets and 2 sided tape. That works well and you can barely see them.
ROAD/RACE
wariosport
15
Mar 12, 2013 03:19 PM
rollinonez
Apr 18, 2006 07:27 PM
Sakamara
Jun 26, 2005 08:53 AM
aray
Oct 25, 2004 02:50 PM
Quick Reply: Installing CF A pillar Gauge Pod
