rs with stock infinity system
Old Feb 25, 2006 | 04:18 PM
drharlequin's Avatar
Angry rs with stock infinity system
okay don't flame me for using the stock infinity system instead of going out and buying aftermarket ones which would be better yada yada yada. i probably should have done that at the begining but since I didn't...
has anyone done this and can you briefly explain how everything is supposed to go hooked up.. i got the head unit, amp, rear speakers, and tweeters. i plugged the head unit in and then plugged the rear speaker in just to see if it would work. but alas, no sound. do i need to run the head unit to the amp for everything to work? i'm kind of new at audio install stuff and i am just plugging stuff in, in the hopes that it will work.
thanks in advance
Old Feb 25, 2006 | 04:41 PM
john91709's Avatar
does the radio turn on?
Old Feb 25, 2006 | 04:42 PM
yes it does
Old Feb 25, 2006 | 04:43 PM
john91709's Avatar
are you sure you connected the speaker wires to the head unit right?
Old Feb 25, 2006 | 04:49 PM
The RS comes with the wire harness that plugs directly into the stock head unit. I did not have to mess with any wires. Speakers also plug in directly.
Old Feb 25, 2006 | 04:51 PM
john91709's Avatar
you should get sound to the speakers if the head unit is powered on. try hooking it up to a different speaker
BGevoIX
16
Feb 27, 2010 05:59 AM
VRSF Tiago
Jun 19, 2008 10:14 PM
dafoe69
Apr 28, 2007 01:54 PM
OkiDvlDog
Lancer Engine Tech
48
Sep 13, 2005 08:17 AM
