question about uego install
Old Mar 22, 2006 | 09:47 AM
lexat20's Avatar
How does everyone run the wires from the o2 sensor to the cockpit. I am about to install my uego and the plug from the line to the sensor is pretty big. My question is how does everyone run the plug? Do you cut the plug, run the wires and solder the plug back on? Is there somewhere the plug will fit w/o cutting the firewall? thanks anyone who can help
Old Mar 22, 2006 | 09:56 AM
JonEvo's Avatar
don't cut the wires!! there is a hole in the passanger side fender that you can use to gain access to the inside with out cutting anything. i will post some pics when i get home from work on my lunch break.
Old Mar 22, 2006 | 10:27 AM
lexat20's Avatar
I am aware of the hole on the passenger side behind the glove box. I don't think that hole is big enough to fit the clip through. Is there another hole that I am not aware of?
Old Mar 22, 2006 | 10:28 AM
JonEvo's Avatar
here,
Attached Thumbnails question about uego install-wide1.jpg   question about uego install-wide2.jpg
Old Mar 22, 2006 | 10:31 AM
JonEvo's Avatar
it doesn't go throw the firewall, like in the pic take off the fender and you will see the ruber peice take it off and then look above the glove box on the right and you will see the hole.
Old Mar 22, 2006 | 10:32 AM
lexat20's Avatar
You removed the front pass. fender? Dang I wasn't expecting that. Thanks for your help and not to sound greedy but anyone have a easier way?
Old Mar 22, 2006 | 11:19 AM
Creamo3's Avatar
Where is the bung that you are using for your sensor? For mine, it is located by the testpipe. I ran the sensor wire to the hole under the passenger seat that the stock 02 sensor runs through. All I had to do was remove the gray part of the clip to get it to pass through the hole and then put it back on once the clip was pushed through the hole. It is pretty easy this way, especially if you are running it to a bung near your testpipe.
Old Mar 22, 2006 | 11:23 AM
lexat20's Avatar
I haven't welded the bung on yet. I plan to put it just b4 the test pipe. I will check out today where the stock o2 runs through.
smokedmustang
31
May 26, 2009 04:38 PM
dcshoeco
23
Nov 20, 2007 07:02 AM
drucea
Oct 30, 2007 08:55 PM
93civEJ1
20
Jun 8, 2007 09:03 PM
Mitsu3
Feb 17, 2007 05:52 AM
