Timing Belt How to...
Old Mar 28, 2011 | 07:37 AM
  #166
mullen's Avatar
Originally Posted by MitsuJoe
No as long as you put the screwdriver in the block for the oil gear you should be fine.
As far as the balance belt you should set the tension with the eccentric pulley and not just slide the new belt on and go.
I gauged the tension of the old balance shaft belt using my finger seeing how far I could slip it in between the belt and I set the new one a hair tighter when I tightened the pulley down...was this incorrect?
Old May 8, 2011 | 03:36 PM
  #167
autotechnica's Avatar
Should be fine.
Old Jun 13, 2011 | 05:11 PM
  #168
sr20det91's Avatar
I noticed in the DSM 2G guide, that is linked to several times in this thread,that it recommends to rotate the tensioner pulley counter clockwise to achieve correct tension. Any thoughts on that? I dont see what the difference would be as long as the grenade pin test passes.
Old Mar 16, 2012 | 10:02 AM
  #169
500evo's Avatar
I need some help, I did everything how its wrote here, my car turns on and then it just truns off? what can be the problem here? I have the Gates Racing belt. Advice would be helpful.
Old Mar 16, 2012 | 10:06 AM
  #170
Z_Lancer_Man's Avatar
Have you confirmed that all your sensors have been properly installed and electrically reconnected? Crankshaft position sensor, camshaft position sensor, etc? Does the car runs for several seconds and then sputter and die or just stop? A video of what is happening would be very helpful. Also, you can confirm that all the timing marks are lined up?
Old Mar 16, 2012 | 10:13 AM
  #171
500evo's Avatar
Everything is lined up correctly, I turn it on it works for like 2 seconds and just dies.
Old Mar 16, 2012 | 10:15 AM
  #172
500evo's Avatar
Also on the air filter there is like cracking sounds coming when i turn the car on. I dont know what the heck is wrong. Did everything right.
Old May 24, 2012 | 11:08 PM
  #173
Evo1001's Avatar
Thanks for the great write-up. I just did my timing belt following the directions in the first post.
Here are some tips based on what I did.
I did not need to use any special Mitsubishi tools, also the screw driver trick to lock the oil sprocket wasn't necessary because when I took the timing belt off, the oil sprocket didn't move on it's own.
The Evo IX mivec cam doesn't have a nut in the center, so I bought this longer nut from Home Depot that was the same size as the mivec cam hole (14 mm) and then used a wrench to hold the cam into position.
For the timing belt tensioner pulley that has the two holes for the special mitsu tool, I just bought this steel rod from home depot, the diameter size that fits snuggly in the holes, and cut it up into 2 one inch pieces, then put them in the holes and used a screw driver in between to twist it until pulley is in the correct position.
Old Feb 23, 2013 | 04:18 PM
  #174
EvoSeanzie's Avatar
How many teeth should be between the marks on the can gears? 18? It seems loose
Old Jul 28, 2014 | 08:18 PM
  #175
rong.'s Avatar
Do to having built motor with no balance shafts should I just skip part about getting them out of phase?
Cajun Power
69
Oct 17, 2015 12:52 PM
Cajun Power
For Sale - Cars For Sale
10
May 26, 2010 05:21 PM
cajun_flash
Apr 19, 2006 06:12 PM
kmxxbadboy
10
Jan 20, 2006 05:53 AM
Cajun Power
Nov 27, 2005 01:21 PM
