Ideas for weight reduction with full interior
Old Sep 26, 2006 | 02:10 PM
AZ EVO IX MR's Avatar
I need some more ideas for weight reduction. I want to do this while keeping the full interior.ex.. front and rear seats, ac, radio ect... So far this is what is done.
Front crash beam
Rear crash beam
Spare tire, jack, tools
trunk carpet
aftermarket exaust.
Old Sep 26, 2006 | 02:11 PM
Jacoby's Avatar
Old Sep 26, 2006 | 02:12 PM
dont think that will help me
Old Sep 26, 2006 | 02:13 PM
Jacoby's Avatar
lightweight wheels and CF driveshaft
Also, some brake kits may reduce weight further.
rotating mass is where I would focus first.
Old Sep 26, 2006 | 02:15 PM
icedomin8r's Avatar
Unless you yank the AC, power steering, radio, speakers, scrape what little sound dampening material there is, etc, you are stuck to what you listed.
I would rather have crash beams then save a few pounds.
The trunk carpet is like 2 lbs maybe
If you want to make a bigger difference, try to shave some weight from the wheels where it matters more.
Old Sep 26, 2006 | 02:16 PM
Jacoby's Avatar
cough.. read my post..
Old Sep 26, 2006 | 02:23 PM
hotrod2448's Avatar
Go to a small battery in the trunk. It takes out about 20 lbs and helps distribution.
Old Sep 26, 2006 | 02:29 PM
Dapper Dan's Avatar
you can peel off all the sound deadening stuff under the carpet and in the trunck....its a PITA but it actually weights alot for how thin it is...
Old Sep 26, 2006 | 02:41 PM
redvolution's Avatar
RacingBrake 332x28 BBK saves 10lbs per front corner. 7 of that is rotating.
Old Oct 4, 2006 | 05:36 AM
kekek's Avatar
Its not worth 20# anymore if you have to run thick guage cable to the trunk. I don't think the extra work of relocating it is worth it, but the rear is light.
Old Oct 4, 2006 | 08:53 AM
mrcox's Avatar
You added weight with your hood. Put a carbon trunk on it and that is a few pounds. You could also pull stuff like sway bars and strut tower bars. Throw some coilovers on it and that is some more weight off of the car. And like other people said some two peice rotors and light weight weels will take more weight off and be more effective than non-rotating weight.
Old Oct 4, 2006 | 08:56 AM
ModifiedMR's Avatar
+1
Old Oct 4, 2006 | 08:09 PM
evo/X's Avatar
imo put you're crash beams back on..or dont. then take out youre whole backseat because why have it in? ....it sounds like you are picky about weight so eliminate the possibility of having passengers in the back, and save weight while doing it.
will taking crash beams out void or hinder insurance claims?
Old Oct 4, 2006 | 08:20 PM
jeremy92awd's Avatar
This should cover what to do.
http://www.buschurracing.com/weight-reduction.htm
Old Oct 5, 2006 | 01:51 AM
ST's Avatar
ST
Search:
https://www.evolutionm.net/forums/sh...d.php?t=202287
Firebat
Sep 17, 2016 09:15 PM
GsrJake
Feb 14, 2013 03:43 PM
mr.green
Mar 29, 2009 10:45 PM
Noize
Feb 25, 2008 04:14 PM
shiv@vishnu
Dec 29, 2003 01:22 PM
