evo ix cam install
Old Mar 29, 2007 | 12:34 PM
FastAzzEvo's Avatar
evo ix cam install
Is there a how to for the cam install on an evo ix?
If not, how much different is it than the viii
Old Mar 29, 2007 | 05:16 PM
JustDSM's Avatar
Exhaust side is identical to a VIII. Doing the intake side on the IX is only slightly different than the exhaust side of a VIII. The only difference is needing a 14mm allen to remove the cover on the MIVEC gear. And removing a 14mm cam gear bolt (IIRC) instead of the usual 17mm of the VIII. Other than that, not much different.
Old Jun 24, 2007 | 10:17 AM
belizelittle39439's Avatar
Apparently it's a little different, I can't separate the cam gear from the intake cam after removing the 14mm bolt. Is there something I'm missing?
Old Jul 12, 2007 | 04:46 AM
PurEvo's Avatar
Does anybody have any pix and more detailed information about removing/reinstalling the mivec intake cam gear?
Old Jul 12, 2007 | 08:22 AM
The mivec cam gear is sitting on there much tighter. After you've loosened the bolt, you will have to "tap" the gear off. At least that's what we had to do with mine. Otherwise it's the same process.
Old Jul 12, 2007 | 10:12 AM
PurEvo's Avatar
I heard something about being careful with the oil spilling when taking off the mivec gear?? Or that's something else?
Old Jul 12, 2007 | 01:53 PM
Redline06's Avatar
yeah, you have to get the oil out or you'll spill.. also when done.. remember to start the car with out the coil plugs in, so you can buil preassure into that cam gear again.. letting some oil get in there..
Old Jul 12, 2007 | 01:54 PM
kreionic's Avatar
Also make sure you dont over tq the mivec cap. I cant remember exactly the tq specs on the cap.
Old Jul 12, 2007 | 03:42 PM
PurEvo's Avatar
I guess I have to get in it to see where's the oil gonna come from.
Man, I really need to get a manual for the evo 9.
Old Jan 25, 2008 | 04:23 AM
joedr's Avatar
EvoM Moderator
Oil will come out of the inlet cam gear. Yeap! From inside the cam gear!
Think like opening the cap (not the bolt) of the inlet cam gear like taking out the oil cap of your valve cover.
Also, make sure you do not spill oil over your timing belt!
Old Jan 25, 2008 | 08:19 AM
FastAzzEvo's Avatar
definitely ,, keep a rag in under there and do many wipes to try to get as much out as possible so while ur working not spills on belt. If you do get a drop or two,, wipe it off.. probably won't hurt nothing, but to much will
Old Nov 18, 2008 | 10:22 PM
93 3gt vr4's Avatar
Old Apr 26, 2014 | 03:56 PM
randy55's Avatar
good evening guys.. i have a little problem with my evo 9 engine.. i just built it with s3 cams and 10.1 compresion. i am putting the cams on time and the crank as well. but my intake valves are getting disformd. there is any how to turn on the engine? does the miven needs to be load? thanks
romogst
Aug 16, 2017 09:24 PM
powerspeed06
Mar 5, 2011 04:58 PM
808boost
43
Jan 12, 2011 08:34 AM
vboy425
57
Jun 25, 2007 11:53 AM
stance
Oct 17, 2006 05:12 AM
