Throttle Cable Relocation Mod!
Old Dec 26, 2008 | 11:11 PM
AlvinHuyN's Avatar
Disclaimer...this will be the easiest DIY ever posted BUT it is a worth while mod. Please do at your at discretion, risks, etc
Throttle Cable Relocation Mod (5-10 minutes at most!)
Tools:
-10mm socket & wrench
Directions:
-Remove the 2 clips holding down the throttle cable with the 10mm socket
-Remove the clips from the cable
-Follow steps 1,2, and 3 in the picture below
Picture without direction so you can see the cable better:
Tips: The bolt on the firewall is in the same spot as the one on the valve cover, just back on the firewall, so if you look at the bolt on the valve cover and then go back to the firewall it'll be there.
Before:
After:
Old Dec 26, 2008 | 11:24 PM
Tsurugi-san's Avatar
Looks easy enough!
So, there's no difference in throttle feel at all? I would assume since you're creating a new bend in the cable that there might be a little extra resistance actuating the pedal?
None, I hope!
Old Dec 26, 2008 | 11:31 PM
LuisIX's Avatar
i did this a while ago then it started binding up after a few thousand miles...its not fun when your WOT and the gas pedal gets stuck..if it was up to me id leave it hidden but mitsubishi did this for a reason..so if you do this becarefu;
Old Dec 27, 2008 | 12:31 AM
AlvinHuyN's Avatar
Which route did you use? If you follow my direction there should be no problemo!
Originally Posted by Tsurugi-san
Looks easy enough!
None, I hope!
It doesn't have any negative effect so far and there are 5-10 others that posted the same mod and they've had their relocated for 2+ years in some cases. If you look at the engine bay thread you'll notice a lot of people have done this. Also, because all you're doing is using the stock bracket, you can also remove the cable from the bracket and put it back in place if you want.
In addition, the bents using this route is not restrictive or "sudden" so the cable is able to move just as nicely. Here are some quotes of other members who modded theirs. Most noticeable in this list is SmikeEvo who is a Mod and Track junkie. He tracks his car pretty often and he has this mod and said it's not a problem!
Originally Posted by bigric09
i did as well, just ran them lower than you i guess... mine sits under the catch can i have there and i have ziptied to the lines (i think brake) that are back there.
Here might be a better pic
mine has never... knock on wood.... and its been like that for over a year now.
you arent crimping the line, you are simply moving it to the back.... it literally took me 10 minutes if that
Originally Posted by SmikeEvo
Image for you:
Used the cable holder that orig. holds the cable at the front of the valve cover. Moved that back to the ACD solenoid and mounted it there. Reattached cable - done.
yes please post pics if you did something different. I just moved mine to behind the intake mani and mounted it to the firewall behind the a/c..... looks clean and feels stock
Originally Posted by mifesto
hmmm i did mine and came out successfully and pedal feel is unaffected... tookinkee can u get me pics of how u did it? made me curious
Old Dec 27, 2008 | 12:34 AM
AlvinHuyN's Avatar
Some more samples of other member's comments regarding this mod:
Originally Posted by shunderwunder
Did mine today & took a few pics. Pedal feels stock so I doubt there is going to be any binding problem. I routed mine in a large "S" shape to keep the bends smooth. The cable bracket from the valve cover was relocated to the solenoid on the firewall. I also zip tid the cable to the wire harness on top of the intake to cut down on movement. I have a couple of paint chips from where the bracket was, but not too bad.
Originally Posted by BoostEEd
Its just a cable. As long as its not binding or catching it can't hurt anything.
Its possible that relocating it could increase the friction and cause it to wear out faster. But if routed well and no sharp bends there should be no issues.
Originally Posted by SUBE KLR
Finally got to relocate my throttle cable. See below pic. Thanks for all the help guys!
ill give u additional pointer to help u....
1.pay attention to where the cable comes out of the firewall... that can be a major source of pedal stiffness if u bend it too much...
2.pay attention to where the cable connects to the throttle body, that should also go in very straight at the end....
goodluck!
Originally Posted by Kerr@xtremeboost
I didn't "tuck" mine, I just flipped it back and clipped it to the firewall. I want to run it under the IM, I just haven't. Pic:
Originally Posted by spdrcr456
thats how i did mine works perfectly.
Old Dec 27, 2008 | 12:41 AM
al3xx's Avatar
I'm sorry...what's the advantage of this mod? I'm unsure where I should be looking for on the before/after pics.
Old Dec 27, 2008 | 12:53 AM
AlvinHuyN's Avatar
Maybe you shouldn't be looking at this mod then? It's to make it so your throttle cable doesn't go across your valve cover. The way it's mounted looks tacky and this mod helps alter that to make the engine bay looks cleaner.
Old Dec 27, 2008 | 02:15 AM
wshihdnevo's Avatar
I guess this thread, can be a little misleading, b/c when people hear..."mod" they think, this is going to add power or help something, whereas this is just for aesthetics.
Old Dec 27, 2008 | 02:19 AM
AlvinHuyN's Avatar
lol true but it's still a modification to your car...I know it's not a huge difference but it's the little details that makes every car just that much better. I didn't know how much that thing annoyed me until I moved it
Old Dec 27, 2008 | 10:55 AM
LuisIX's Avatar
i did it the same way your showing alvin..after a couple miles it started to get stuck
Old Dec 27, 2008 | 10:58 AM
20gmr's Avatar
i always un-clip mine from the valve cover when checking plugs or something and if you slip it under the strut bar it stays and i forgot to put it back on several occasions now lol no issues
Old Dec 27, 2008 | 11:55 AM
heel2toe's Avatar
Cool! I think I am going to try this. The cable never really bothered my there however if it causes no issues in the new location then its a no brainer to me. It def looks much cleaner tucked away! Nice work!
Old Dec 27, 2008 | 01:16 PM
derangedazn's Avatar
will this void your warranty?
Old Dec 27, 2008 | 01:28 PM
Smike's Avatar
Hey-o, good write-up. old photo of mine from WWIII...
...not much has changed
Old Dec 27, 2008 | 01:29 PM
EvoHung's Avatar
I did this 4 years ago. ZERO problems whatsoever. I also removed all of those metal tubes sitting on the corner of the valve cover. ZERO issues as well. And mine is daily driven.
