Stealth Airbox Mod
Old Apr 26, 2010 | 10:12 AM
  #106
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by JustJeff
I could put pics up later, but its just the snorkle and the top of the airbox. Its sitting on the edge of my UICP and directs air over the filter. I used some 3mm Sticky tape to make sure the top part did not fall off onto my filter, like it did when I first put it on.
I'm very interested in running something very similar, that's why I asked.
That would be awesome of you if you could put up some pictures.
Old Apr 26, 2010 | 10:18 AM
  #107
4xforce's Avatar
Hey Golgo, why would you not just use the OMG filter like we have discussed previously. It flows great and the stealth mod isolates the filter from the under hood temps. I have run an open filter(Perrin) with the snorkle just sitting there and there was no noticeable difference than without the snorkle. Not to mention you are back to square one with sucking in under hood hot air and no stealth benefit. Just my .02
Old Apr 26, 2010 | 10:26 AM
  #108
golgo13's Avatar
EvoM Community Team
Veteran: Navy
In both cases I'll be using the stock air box 100%
I'm going to hack up a used SAMCO tube and see if I can get a PERRIN filter to fit under the box, since the stock PERRIN tube is too long.
Once that happens, I plan on doing back to back testing @ GST between the OMG and the PERRIN filter on the SAMCO tube.
Old Apr 26, 2010 | 10:31 AM
  #109
4xforce's Avatar
In a previous post I described how the Perrin will not work. My samco hose could not be trimmed any more on the MAS end or the MAS would not fit any longer. The hose begins to taper. The Perrin is considerably taller than the OMG. I was not willing to take the chance of trimming any off the compressor side of the tube because there is not much "meat" there to make a good connection if you trim some off. I would not waste my time unless you are willing to sacrifice your samco hose to find out the hard way. By the way your dyno testing may not reflect real world conditions especially considering nature the parts being tested.
Old Apr 26, 2010 | 10:36 AM
  #110
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I'll go back and take another look at your previous post.
Old Apr 26, 2010 | 12:26 PM
  #111
4xforce's Avatar
I might add something I said before in a previous post in this thread is that if you move the MAS far enough towards the passenger side of the car for the Perrin to fit your MAS wiring harness will not reach. This would be the main reason the Perrin would be out of the question unless that is if you are so inclined to try to extend the connector wiring. Would seem like way too much hassle for little if any benefit.
Old Apr 27, 2010 | 12:21 AM
  #112
nanashi's Avatar
Will you be doing this on a stock tune? If your car is tuned for a specific intake it may skew the results. Just throwing that out there since I saw another post comparing a bunch of different intakes on the dyno but they overlooked the fact that the filter that made the highest numbers was what the car was tuned for with in the first place.
Old Apr 27, 2010 | 09:47 AM
  #113
golgo13's Avatar
EvoM Community Team
Veteran: Navy
My goal is to see which set-up is going to net me the most gains back to back with the parts on my car.
That means re-dyno tune with each piece to see how they perform.
Old Apr 27, 2010 | 10:24 PM
  #114
nanashi's Avatar
Ok cool I like that idea. Will you be posting up results on here?
Old Apr 28, 2010 | 09:31 AM
  #115
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I plan on it, but that might be months away.
Old Jul 21, 2010 | 04:02 AM
  #116
nanashi's Avatar
Does anyone else find this to be a tight fit with the SpeedElement filter?
Old Jul 21, 2010 | 04:13 AM
  #117
chad99evo's Avatar
Originally Posted by Kinmar_X
why?
california would be my reason
Old Jul 21, 2010 | 10:08 AM
  #118
4xforce's Avatar
It's a pretty tight fit and I'm using a samco hose that I have trimmed a little. You might consider doing that or if you are using an intake pipe that you can't trim try using a dremmel and cut away some of the plastic on the inside of the box to gain a little room.
Old Sep 22, 2010 | 12:59 PM
  #119
hokiruu's Avatar
How ironic. I must have subconsciously remembered reading about this long ago. I was going to go with the OMG in hacked stock airbox, then rememberd the good results from the Perrin, ordered one thinking I might be able to make it fit, and now read this haha.
Golgo, what have you found works best for you since?
Old Sep 22, 2010 | 01:14 PM
  #120
B Fletch LV's Avatar
This is a really great idea! Ill have to do it when I get a new intake. "of course its stock! just look at that intake box!" haha
