Stealth Airbox Mod
Old Mar 9, 2010 | 10:59 PM
  #61
06MREvo's Avatar
I ran this setup for a while...I was using the AMS K&N filter with maf adapter...to be honest I don't think any other air filter will fit in there...that K&N filter was pretty small...
Old Mar 9, 2010 | 11:08 PM
  #62
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I wonder if I can hack the airbox so the filter has enough room to poke out the driver's side.
It just has to not draw attention, that's the ultimate goal.
Old Mar 10, 2010 | 06:01 AM
  #63
icrnk's Avatar
Let us know
Originally Posted by JordanS4
great idea! I was going to put my stock airbox back on and noticed it was cracked at the bottom. Now I have a use for it. I just hope my AMSoil filter isn't too big and will fit in there with the stock pipe.
I would like to see how the Amsoil filter fits
Old Mar 10, 2010 | 12:45 PM
  #64
sphinxof2006's Avatar
http://www.speedelement.com/index.ph...mart&Itemid=38
just buy what fits it's 45 shipped ....
Old Mar 10, 2010 | 12:53 PM
  #65
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I like the performance of the Perrin, which was why I wanted to run it.
On 91 octane every little bit helps.
Old Mar 10, 2010 | 10:44 PM
  #66
Ur from the bay go e85 if your worried bout power . That Perrin looks like u can shove it in there!
Old Mar 11, 2010 | 07:34 AM
  #67
icrnk's Avatar
Any information on it's filtering and flow compared to others such as Amsoil, Perrin, AEM Dry Flow. Who makes this filter?
Nevermind, looks like this isn't really a permanent type filter: "You can clean them by using compressed air to get the dirt and particles out. It is recommended to replace them after 10k miles or so."
Source: https://www.evolutionm.net/forums/ve...-shipping.html
Old Mar 11, 2010 | 08:09 AM
  #68
evolutong's Avatar
Any improvements on the cut or the OP's cut still the best?
Old Mar 11, 2010 | 09:12 AM
  #69
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I really wish it was that simple.
The amount of fuel I consume combined with where I live in relation to the stations makes it way too inconvenient.
My build will support E85, so I'll hold out until there are more stations.
Old Mar 11, 2010 | 09:38 AM
  #70
4xforce's Avatar
Back to the filter discussion it looks to me that you obviously could use the OMG filter from SE but it appears to be much larger than the one from GST. Now if you are just looking to conceal the filter then the SE filter might work for you. My take is that you can still see the filter from the front by the pics that were provided. I would aim to conceal the filter AND most of all get the benefit of isolating it from engine heat as much as possible. The GST filter or one of similar dimensions appears to do this with only having to cut the bottom of the box only. Some posts from 9sec9 and Indyevo I believe have done some research on the effectiveness of isolating the filter as much as possible. Check out 9sec9's website(9sec9.com) and checkout the heated air-block. This will show you how beneficial this approach may be. Just my 22 cents
Old Mar 11, 2010 | 08:30 PM
  #71
I have the GST filter u need to cut the box one way like that thread:
https://www.evolutionm.net/forums/8077223-post53.html
For What i did is take this piece
http://yfrog.com/0jautocross0032j
http://yfrog.com/5bdsc03952eoj
http://yfrog.com/1ndsc03954xj
AND A VIDEO TO HELP U UNDERSTAND :]
I MADE THIS LOL
http://www.youtube.com/watch?v=l2K5vyEoAho
Old Mar 11, 2010 | 09:06 PM
  #72
4xforce's Avatar
^^Thank you!!
Old Mar 11, 2010 | 09:15 PM
  #73
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Nice!
What's the loose piece for?
Old Mar 11, 2010 | 09:38 PM
  #74
To cover the filter in the front so it's a real stealth air box!!! Pm me if u have ? Or just post up
Old Mar 11, 2010 | 09:45 PM
  #75
Originally Posted by 4xforce
^^Thank you!!
your welcome , pics couldn't get it accross IMO so hell I decided to make a vid , hope this helps many people!
