Oil pressure sender
Old Jan 19, 2004 | 07:06 PM
  #46
KillaSweep's Avatar
The Gauge is maxed out only when there is power on. When the power is off it goes back to zero. It did this even before I ever hooked the signal wire up to it. After installing the sender as a replacement oil plug and hooked everything else....it didn;t change. I am baffled. The pressure guague I have hooked up just moves up like a mm when powered on...even with no signal going to it.....i'm guessing this is what the temp gauge should be doing....but it isn;t for some reason. I am trying to get ahold of 42 to see if they know of anything.
Old Jan 19, 2004 | 09:11 PM
  #47
KillaSweep's Avatar
Well here is a pic of the finished product...notice how the oil temp gauge is on the right...completely pegged out....anyone know why? Everything is hooked up right.
Old Jan 19, 2004 | 09:12 PM
  #48
KillaSweep's Avatar
And one more....
Old Feb 10, 2004 | 02:00 PM
  #49
bullfrg's Avatar
Whatever happened with 42 Draft Designs working on an Evo package? Do they offer one now? I still think their product looks to be about perfect for what I want.
Old Feb 12, 2004 | 01:58 PM
  #50
KillaSweep's Avatar
Yeah they are making it....they are actually making a fitting right now to make the oil pressure sender just screw into the existing hole next to the oil filter. They are sending me the piece to test it...then everything should be good to go. Their products are top notch!
Old Feb 12, 2004 | 02:17 PM
  #51
bullfrg's Avatar
That is what I wanted to hear I am going to be ordering their guage pack soon then.
Old Feb 12, 2004 | 03:46 PM
  #52
KillaSweep's Avatar
You won't find a better deal. The wirin they send with it is awesome too. It so easy you feel like you are doing somethign wrong...lol.
Old Feb 13, 2004 | 09:06 AM
  #53
EVOwhat's Avatar
KillaSweep, did you ever get your oil temp gauge worked out?
Old Feb 13, 2004 | 10:30 AM
  #54
whiterexman's Avatar
What adapter do I need to get if I have an oil presure gauge already?
On a second thought, what about both the Oil Temp and Oil Presure gauge? What adatper do I need to get if I want to hook up both OilTemp and Oil Presure gauge?
TIA
Old Mar 31, 2004 | 07:44 AM
  #55
sillypuddy's Avatar
Originally posted by propellerhead
In case someone is looking for one for a 3/8 to 1/8NPT adapter, they can be found here near the bottom of the page.
For my own installation I'll use an AN-4 flare adapter and plumb with braided steel up to a mounting point on the firewall using one of these. For some reason that sender being down in the clutter around the filter would make me nervous. That's just me tho'...
I plan to use a steel braided line and mount the T and sender unit on the firewall, some other site say that with the engine vibration, the T will eventually fail and it would be nasty
-joe
Old Jun 25, 2010 | 04:57 PM
  #56
hahnsolo's Avatar
does any one knw if i can use both of the allen plug can be used or just one of them on the oil filter housing? im trying to hook up a oil pressure and oil temb gauge.
selp
Jul 5, 2014 04:37 PM
Jingming88
Aug 22, 2011 07:03 AM
sleepy_rps13
May 12, 2011 01:02 PM
Charlie-Y
15
Jan 30, 2010 09:46 PM
EvilBlueEvo8
Oct 26, 2009 01:41 PM
