How to level car for Tcase fluid change/check
Old Mar 22, 2011 | 08:11 AM
motocooney's Avatar
I have myself all paranoid that my method of making sure the car is level for T-case and Trans fluid changes isn't right.
I have been using a level on the metal behind the sideskirt for front to back and a level on the underbrace for side to side.
Is this good enough?
My garage isn't level enough to make sure that the tcase is filled properly with car sitting on ground.
Also, it's hard to tell from the shape of the Tcase what direction would lead to overfilling/underfilling.
Thanks
Old Mar 22, 2011 | 08:20 AM
binky's Avatar
Thanks
I usually will make the car as level as possible (using jack stands). Then I fill the T-Case up until fluid leaks out. Then depending on how un-level the car is I'll have someone else pour more fluid in while I'm under the car and when I feel there's enough (before more leaks out), I quickly put the plug back in.
-Bink
Old Mar 22, 2011 | 08:51 AM
Alexl08's Avatar
I over fill mine and never have a problem
Old Mar 22, 2011 | 08:52 AM
boostedwrx's Avatar
I attach a magnetic level on the undercarriage when I have the car in the air. I drive up my Race Ramps then jack the rear up by the diff. Make sure to drive the car around the block then try to stuff more fluid in it.
Old Mar 22, 2011 | 09:37 AM
motocooney's Avatar
Okay, so you guys don't seem to concerned about overfilling?
That was my main worry. I know I'm not underfilling. But I was reading about overfilling the tcase leading to seal problems, fluid leaks and then tcase death.
UGH. stupid forums if you read enough I think you can convince yourself that there's a problem with pretty much everything.
Just went out and checked again. It's definately comin out of the fill hole when I pull the plug out. So I think I'm good.
I would think that a couple extra ounces wouldn't be bad.
I've changed it like 4-5 times before and never worried about it.
I guess I'll continue not worrying about it
Old Mar 22, 2011 | 10:08 AM
Alexl08's Avatar
^^^ couldn't be true enough Ive had mine overfilled because a buddy of mine said when he bought his built t case they said to over fill it a bit to adjust for his style of driving.
Old Mar 22, 2011 | 10:20 AM
erald01's Avatar
thats how you tell the level by overfilling it. When the fluid starts to spill out then its filled full.
Old Mar 22, 2011 | 10:54 AM
Alexl08's Avatar
yes but we jack our cars up on one side and fill it
Old Mar 22, 2011 | 10:58 AM
binky's Avatar
I don't. I do it on both sides.
-Bink
Old Mar 22, 2011 | 11:01 AM
Alexl08's Avatar
well to each his own I or he has seen no affects after putting some extra in it
Old Mar 22, 2011 | 03:57 PM
motocooney's Avatar
I generally have tried to jack up all four corners and get the car as level as possible. That's a lot of extra work when filling can be accomplished by just raising the passenger front.
I guess it would be good to know HOW MUCH Extra fluid can be put in the Tcase when the car is high on the passenger side.
I really don't see slight overfilling as a problem. I mean stuffing an entire quart into the thing could be bad though right?
I guess my question is "How much is too much?"
Old Mar 23, 2011 | 12:18 PM
Alexl08's Avatar
I just jack up one side decently high fill till it comes out put the plug back in and let her eat
Old Mar 23, 2011 | 12:25 PM
erald01's Avatar
You will never be able to fill an extra quart so dont worry. If you worried so much about it bring it to my cousins shop and will do it for you, just pay for labor.
Old Mar 23, 2011 | 02:37 PM
motocooney's Avatar
Paying someone to do it for me is totally out of the question. Just had some concerns about having the right amount in there. Which considering the endless threads about Tcase death, i don't think is abnormal.
Also, driving to Canton for a fluid change just seems retarded
Thanks for the offer though.
Old Mar 23, 2011 | 02:45 PM
06RedRalli's Avatar
I always just jack up the passenger side as high as I can...then fill until the fluid starts to come out...and then put the plug back in and call it a day...
I've always done it this way and never had any kinds of problems...
EvilDSM97
Jul 16, 2016 06:10 PM
roni4g63
Jul 15, 2015 09:25 AM
VT Mitsu
May 18, 2015 09:41 AM
jtcarstens
Sep 18, 2014 07:01 PM
StreetThisEvo
22
Jul 23, 2012 03:48 AM
