How to remove seatbelts
pop the plastic bolt cover cap off the upper belt anchor, remove the bolt,
pull off the black rubber weather strip in both door openings just where it goes along the edges of the trim you want to remove.
believe the B pillar piece is above both the trims it overlaps at top and bottom, so just pull it straight out to pop the clips
if another trim piece is on top at either end, pull it partially out first, then the B pillar one.
Make sure and get the top anchor back together the same way, the belt has to pivot freely, compare to the other side if unsure.
evilution8
22
Feb 17, 2007 09:37 PM
