Install a Whiteline KCA395 roll center correction kit on an Evo without a shop press
You should use the Whiteline snap rings. If the ball joints are fully seated they should work. I don't know what was on there before, but there are no OEM snap rings. The OEM ball joints are non-serviceable and normally would require replacing the entire control arm if in need of replacement.
thanks for your reply... I was talking about the c clip removed from original ball joint since I was able to remove it without damaging it and seems serviceable still... just trying to avoid having to sand down the arm around the ball joint if I can get away with it... was just wondering if anyone had done that before, using the previous c clips that came with original ball joints... appreciate the help and as y'all can see I'm a newbie lol
scherejs
29
May 25, 2020 02:17 AM
railgunner50
14
Jul 25, 2013 09:41 AM
CrAnSwIcK
24
Jun 22, 2012 10:48 AM
black95tt
62
Dec 18, 2010 11:19 PM
