HVAC Repair - MEGA Guide
Old May 25, 2012 | 01:30 PM
  #61
SilverShadow03's Avatar
Originally Posted by PMRSTL
I was able to find plastic piece in Ebay for $22 including shipping.
2002-04 LANCER - Heater Control Panel Switch Knob Shaft
http://www.ebay.com/itm/2002-04-LANC...item3a6b627065
Originally Posted by sr20ve
Thanks, this is what I've been looking for.
So is this an option for those just wanting to replace the heater shaft???
I found the same ebay item and wanted to know if anyone has successfully replaced their heater control SHAFT in their Evo or is the just for the Lancer?
I drive a 2003 Evo 8.
http://www.ebay.com/itm/2002-06-LANC...f4c811&vxp=mtr
Old May 25, 2012 | 01:55 PM
  #62
Airman X's Avatar
HUGE wite up, and great picture
Old Jun 18, 2012 | 05:51 PM
  #63
Huntington MR06's Avatar
anyone know if you can replace just the HVAC control shaft if just the plastic is broken and not have to buy the whole box?
Old Jun 18, 2012 | 06:09 PM
  #64
zstryder's Avatar
Awesome thread. I changed the gears and that fixed my problem. I'm so glad it wasn't the mixbox! (knock on wood)
Old Jun 18, 2012 | 11:44 PM
  #65
bump
Old Jun 19, 2012 | 05:19 AM
  #66
GaBe511's Avatar
^^^Are you talking about the piece discussed 3 posts up?
Old Jun 19, 2012 | 12:03 PM
  #67
yes. i purchased the Temp plastic shaft from ebay... trying to see if you can replace that piece without purchasing a new box.
Old Jun 19, 2012 | 12:08 PM
  #68
BUMP for the same question I asked. I posted the ebay link to show the actual part I was referring to. I have not purchased it yet and want to know if it is a piece we can replace ourselves....
Old Jun 30, 2012 | 08:26 AM
  #69
IronPalm's Avatar
i'm in the same boat.wondering if i can ****** this for 22 bucks or so or have to spend 200-300 on the whole assembly
Old Jun 30, 2012 | 04:14 PM
  #70
mt057's Avatar
I just pulled apart the assembly and it appears to be the correct part. I am going to order one and install it.
Old Jul 10, 2012 | 05:28 AM
  #71
mt057's Avatar
I have received the part and am happy to report that it is the exact same. My knob shaft is in full again.
Old Jul 10, 2012 | 10:07 AM
  #72
Is it easy to replace? I'll be ordering mine asap.
Thanks for confirming this for us!
Old Jul 10, 2012 | 01:04 PM
  #73
mt057's Avatar
Not that bad at all.
Old Aug 22, 2012 | 05:24 PM
  #74
mdost03's Avatar
I am probably going to order the plastic shaft and replace my busted one. I have yet to pull the HVAC unit out and disassemble it. How long did it take to replace? Any issues you experienced/tips to share? Any help would be appreciated while I gather parts to fix mine.
Old Aug 22, 2012 | 08:10 PM
  #75
mt057's Avatar
I sent this to another member this morning to try and explain some of the process. Hope it helps.
I have to recommend getting the revised gear set as well to help prevent future breaks.
I would put a couple of hours aside. It is really not that hard to get to. The main issue is with adjusting the gears to meet up just right.
Remember that the dial causes the main gear to turn in the same direction. So you turn the temp dial clockwise so will the main gear for it under the dash. Also lightly adjust the screw under the dials to help how hard the dial is to turn. I had it too loose so it did not "click into" max a/c. Gave the screw a little turn and it was perfect.
When pulling the knob out it will cause a little gear it fall out of place. You will need to get that in place and adjusted just right to have full range of motion with the dial. I recommend looking at the other gear still in place to get an idea of how it wants to be. This is one spot that I recommend starting from completely clockwise or counter clockwise, not some random spot. It makes it easier to line every thing up.
When getting the circuit board out you will have to pull it gently forward to get to two clips behind it to remove a connector. Make sure that every thing is pushed back and remove the clips and connector. Then it should come out.
With the circuit board out you can now get to that gear that connects to the shaft that fell out when you removed the old shaft. Get the knob inserted through the board into the small gear (pinion) and get that lined up with the longer flat gear (rack) on one end that way you have full range of motion.
I am considering writing up a how to with pictures after trying to simply explain it to you .
It is not that hard though. Just sounds annoying. Let me know if there is anything else I can do to help.
The controls are sold as a unit so the service manual does not show anything inside the unit.
