How to make cheap coil on plug setup
Old Aug 9, 2013 | 10:04 AM
  #331
iceman1189's Avatar
So I finally got my civic coils from a friend who had a civic that I swapped motors for she had a extra set can't say no to free. Installed them the other day and WOW its so much better in every way, I had to remove my ignition booster but it was still a great improvement over the oem coils. Still need to fab up a plate but they fit under my ignition blade cover so win win all around. Personally I wouldn't waste my time with a Hyundai coil swap guys. I know it's plug and play and all but wiring in the COP setup isn't very hard to do I did it completely as a full plug and play harness for mine in like an hour and if you shop around can be super cheap too.
Old Aug 18, 2013 | 10:08 PM
  #332
azzaevoviii's Avatar
just ordered my parts for this, just want to confirm has everyone upp'd the ignition fuse to 15amps from the original 10 amps as per the spoolinup page http://www.szabaga.com/store/files/directions.jpg
Old Aug 19, 2013 | 06:13 AM
  #333
Just noticed on the previous page that the 15 amp fuse is the way to go
Old Aug 27, 2013 | 11:46 PM
  #334
iceman1189's Avatar
have needed to change my fuse does it make any difference?
Old Sep 19, 2013 | 07:06 AM
  #335
her name is eva's Avatar
Getting everything tomorrow. Can't wait to see if this helps with my my problem. By the way using honda k series also, any info out there, That hasn't been mentioned in this thread?
Old Sep 20, 2013 | 07:20 AM
  #336
johnnydemz4G63's Avatar
I made A cop kit and been having trouble with misfiring, bucking for quite some time. I gap'd my plugs A million times and finally got them dialed in. So now I'm running 1 step colder plugs and can't dial em in to save my life, yes all coil packs are working properly and there is no cracks on the boots. I've read that you guys up the amps of the ignition fuse, could this be the culprit?
Old Sep 20, 2013 | 07:32 AM
  #337
ronaldo9's Avatar
Use the 15amp fuse and report back.
Old Sep 20, 2013 | 09:02 AM
  #338
llDemonll's Avatar
15A fuse isn't going to change anything, but I would use it over the 10A fuse. Many people have reported the spoolinup blowing 10A fuse and Spoolinup suggests a 15A fuse, as does Sparktech I think
What plugs are you using johnnydemz4G63? What are they gapped at?
Old Sep 20, 2013 | 12:19 PM
  #339
When I was running ngk's I gap'd them all the way down to .018 and had no misfire. Now I'm on Bosch 1 step colder gap'd at .018 with misfires. When I am in low rpm and go WOT I get big time misfire
I've recently (yesterday) placed my OEM plugs back in and gap'd to .020 and have no misfire but I do have pre-detination.
When I put my cop together I did everything correct and carefully took my time. I will pop in A 15A and see what happened.
Old Sep 20, 2013 | 12:46 PM
  #340
llDemonll's Avatar
I'm at .026 on stock plugs ILFR7H and have no misfires. what coils are you running?
If you're having pre-detonation with the stock plugs and coils in I would get that sorted out first. If you really do have pre-ignition you shouldn't be driving the car unless you want to rebuild your motor soon
Old Sep 29, 2013 | 02:00 AM
  #341
Zacharyd_b's Avatar
Great idea!
Thanks for this! I will definitely look into doing this to my evo asap!
Old Oct 18, 2013 | 12:25 PM
  #342
nelale2's Avatar
How can I determine if a coil pack will work for a COP?
I have a set of 2008 lancer coils and would like to know if they would work.
Old Nov 4, 2013 | 05:02 PM
  #343
Yang_2012's Avatar
NICE!
Old Nov 27, 2013 | 07:15 PM
  #344
jpiraino's Avatar
Picked up some Civic coils today. Thanks for the share and saving the community some money!!!
Old Nov 27, 2013 | 07:36 PM
  #345
EvoGSR8's Avatar
I definitely needed to read this thread!
