DIY COP Coil On Plug Setup
Old Apr 28, 2013 | 04:11 PM
  #31
llDemonll's Avatar
For the second set I wired them a bit different. I'm not going to change the write-up because this requires soldering and I know not everyone has a soldering iron / knows how / etc., etc. As long as they are wired correctly, it doesn't really matter how you set them up
Size:  10.6 KBName:  azT1ilTm.jpg
Size:  9.9 KBDIY COP Coil On Plug Setup-ajiglkym.jpg
On this one I chose to split the wires in-line as opposed to in the connector that plugs into the factory harness. I wanted to do this to use the grommets that come with the connectors (which you can't do with two wires in each connector) and just for the heck of it to try something new. I haven't sleeved any of it yet but you can see how it will work in the end. The connectors are grey because they're ones that I bought used from a member on the forums
Finished Result:
Size:  16.4 KBDIY COP Coil On Plug Setup-y43trxqm.jpgDIY COP Coil On Plug Setup-e8vhvf5m.jpg
I ended up painting this plate with VHT Wrinkle Black spray paint I picked up from NAPA just to see how it'd turn out. I should have not been lazy and sand the plate / prep it before spraying because while it sticks well, you can scratch it off fairly easily. The stuff is weird, it's not like normal paint. It feels rubbery to the touch like it's still curing almost (36 hours after painting it). It looks great, I'm just not sure how well it'll hold up if you plan on taking it off and on much. With black connectors and all black cabling it would make it look pretty bad-*** though!
Old May 25, 2013 | 05:01 PM
  #32
cool_as_crap's Avatar
Nice thread! I'll be doing this shortly.
Old Jul 5, 2013 | 07:22 PM
  #33
WikdEvo's Avatar
is there a place online where you can order nice heat shrink and wire covering? What places locally would sell this type of materials?
Old Oct 31, 2013 | 07:41 PM
  #34
Maddy88's Avatar
Anyone know where I can find a set of coils for under $100?
Old Nov 2, 2013 | 07:05 PM
  #35
Would there be any advantage to use larger wire? Like 18 gauge?
Old Nov 2, 2013 | 10:44 PM
  #36
llDemonll's Avatar
*shrug* i use what i use because it fits perfectly in the rubber seals. 18 gauge won't fit with it. but really, no, since the 20 gauge isn't being over-worked moving to 18 gauge won't have any benefit
Old Nov 2, 2013 | 10:48 PM
  #37
nelale2's Avatar
How can I determine if a coil pack will work for a COP?
I have a set of 2008 lancer coils and would like to know if they would work.
Old Nov 3, 2013 | 11:23 AM
  #38
llDemonll's Avatar
Figure out the dwell times. evo need somewhere right around 2.4ms
Old Nov 4, 2013 | 02:27 PM
  #39
OhioWhiteEvo8's Avatar
damn ill have to consider doing this set up
Old Dec 3, 2013 | 06:09 PM
  #40
Aus_dtuned's Avatar
Does anyone know if the Denso 90919-02248 coils will work for this? they look identical to the 90919-02244
Old Dec 3, 2013 | 06:39 PM
  #41
hiboost2.0's Avatar
Yeah those will work fine.
Old Dec 3, 2013 | 06:43 PM
  #42
Ude Lose's Avatar
bump for great info.....
Old Dec 6, 2013 | 01:12 PM
  #43
jdbinspired's Avatar
Nice!
Old Dec 14, 2013 | 10:44 PM
  #44
turbochris88's Avatar
ill be doing this mod very soon!!
Old Dec 15, 2013 | 11:39 AM
  #45
Canadian-Ix's Avatar
Just finished up mine using 02240's. I hardwired mine in instead of using the connectors on either end. Car runs and drives noticeably better, initial startup was very smooth! Total cost was $80 canadian. I ended up using a 1/4 aluminum plate, I couldnt find what thickness anyone used, stretched the springs a bit and no issues. Thank you for the awesome writeup and info. Merry Christmas!
