DIY COP Coil On Plug Setup
Old Jan 3, 2014 | 10:24 PM
  #46
MAD8's Avatar
Badass. I really like this, I may need to go back to this at some point. Nice job.
Old Jan 11, 2014 | 03:02 PM
  #47
randomdriver's Avatar
I am very curious about the size of the wires. Does it matter if I got 16 or 18 or 20?
Old Jan 11, 2014 | 03:47 PM
  #48
llDemonll's Avatar
I make setups for locals and use 18awg military-spec tefzel wire
you can use 20awg if you want, but the normal +12v wires on toyota's are 18awg
normal 18awg wire is too large for the insulators so if you want to use 18awg it'll need to be thin walled wire
Old Jan 11, 2014 | 05:54 PM
  #49
eflores's Avatar
I think I found my next project... Great write up!!
Old Jan 13, 2014 | 06:03 PM
  #50
OhioWhiteEvo8's Avatar
Do cop kits for evo 9 work on the 8? Is it just the mounting point of the plate cover that are different?
Old Jan 14, 2014 | 07:32 AM
  #51
llDemonll's Avatar
Yes, just the mounting plate is different. Kits for the 8 will not work on the 9 though without modification
Old Jan 27, 2014 | 08:14 AM
  #52
cool_as_crap's Avatar
A 9 plate will work on an 8 with no modification. The mounting points are the same.
Old Jan 27, 2014 | 08:24 AM
  #53
Can anyone recommend an insulated wire wrap that will stop the interference to my radio? I only have it wrapped in electrical tape and the interference is pretty bad.
Old Jan 27, 2014 | 08:55 AM
  #54
llDemonll's Avatar
correct; the only difference between the two is the evo 9 has some notches that need to be cut to clear the valve cover. 9 plate will work fine on an 8, but 8 plate will not work on a 9 without modification
Are you sure this is what's causing it? unless something was wired wrong there's nothing in this setup that should affect the radio. maybe a ground for the radio came loose or something?
Old Jan 27, 2014 | 10:02 AM
  #55
I'm pretty sure, it didn't have feedback before I put in the coils.
I'm going to try wrapping them in foil to see if that does anything.
Old Jan 27, 2014 | 10:56 AM
  #56
nelale2's Avatar
Try shielded wire, like twisted shielded pair.
Old Jan 30, 2014 | 12:55 PM
  #57
EvoG1988's Avatar
Amazing
Old Apr 11, 2015 | 08:06 AM
  #58
0t73r's Avatar
Thank you very much llDemonll car definitely feel much better. Steering response feel lighter too.
Old Apr 12, 2015 | 06:13 PM
  #59
SpoolinUp's Avatar
Silver Sponsor
Are these genuine Denso? I've tried a few sets of coils in the past and had some interference with Denso knockoffs. There are some fake Denso coils out there that look EXACTLY like the real thing too, except they perform like garbage!
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old May 31, 2015 | 06:27 PM
  #60
Werdna06's Avatar
Awesome write up. I'll add this to my list of diy's for my IX.
