bov fluttering
Old Apr 14, 2014 | 05:49 AM
notorious271985's Avatar
bov fluttering
How do I tell i have bad Bov? I recently upgraded to 9 turbo, 1000 cc fuel injectors, aem e85 fuel pump and e85. I went from 15 lbs of boost to 30 lbs. I have a forge rs bov valve and I have tried adjusting it to different psi, still getting a loud fluttering sound at half throttle
Old Apr 14, 2014 | 07:09 AM
sujinX's Avatar
did it flutter before with the same forge rs bov?
partial boost and stiff bov spring setting will cause fluttering.
u can do a boost leak to see if the bov is leaking.
Old Apr 14, 2014 | 11:11 AM
cfdfireman1's Avatar
Get rid of the forge rs bov valve.
Old Apr 15, 2014 | 04:33 AM
It never did that before...I think im just going to get rid of it and put my big boy pants on and get a tial lol
Old Apr 15, 2014 | 04:58 AM
15 psi and it didn't flutter? Wow!
Old Apr 17, 2014 | 06:05 AM
Evo2372's Avatar
I thought the RS was good for up to 23psi from looking at the specs last.
Old Apr 19, 2014 | 05:50 AM
Yea they'll hold a shi t ton of boost, they just won't let it go and modulate it at part throttle very well.
Old Apr 21, 2014 | 09:04 PM
DRO.Evo8's Avatar
+1 on getting oem style dv. Evos don't like aftermarket dv's.
Old Apr 23, 2014 | 09:20 AM
Vrbigdish's Avatar
I purchased my car with a hks bov and had nothing but issues. Went to stock and it's been mint
Old Apr 24, 2014 | 04:40 PM
blakecakes's Avatar
Just something to think about, I've ran I to this in the past and have found that installing a vacuum check valve in the line from your manifold to the bov stopped the flutter of my turbo.
Make sure it's installed so that the intake takes a vacuum on the bov.
The "pills" in the stock lines are not enough to prevent the flutter. Good luck.
Old Apr 24, 2014 | 06:37 PM
slowsrt4:('s Avatar
OEM 9 BOV is where it is at, if you're running more than 30 PSI though I would go with a TIAL, and if you're running more than 30 psi, you better be on speed density and not maf
Old Apr 25, 2014 | 04:00 AM
luck.
Never thought of installing that...appreciate the help
Old Apr 25, 2014 | 04:02 AM
I am running 30 psi right now so I think a tial is where its at.. my mechanic recommended going sd, but why is it a must after 30 psi? Just need more info on that
Old Apr 25, 2014 | 11:29 AM
Wrong, wrong and wrong.
There are no "pills" in the recirc valve line, you're thinking of the boost control line.
A check valve in the recirc line would cause the valve to open under boost, you need pressure to the top of the valve to keep it closed under boost.
Old May 11, 2014 | 06:54 AM
GSXPimp's Avatar
Yes pressure the top to keep it closed like cfdfireman1 said
TrinaBabe
14
Oct 10, 2014 10:09 AM
Tachyon56
19
Sep 22, 2010 08:07 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
06GraphiteEvoIX
32
Mar 11, 2010 08:45 PM
dvd_mi
Mar 1, 2010 03:02 PM
