EGR Insufficient Flow P0401 Issue
Old Jan 15, 2021 | 12:55 PM
mccloed's Avatar
So, The only reason I am writing this is because when I had this issue and nothing I read was working. First I made sure all the hoses were attached. I tried replacing the EGR valve itself. Still got the code after 30+ or - miles. I tried replacing the EGR solenoid. Still got the code after 30+ or - miles. I tried replacing all the hoses. Still got the code after 30+ or - miles. I tried clearing out the EGR system with a coat hanger. Still got the code after 30+ or - miles. You can see a pattern here.
I had tried everything I read about and nothing fixed the issue. So, I decided to check where the white and yellow stiped hoses attached to the throttle body to make sure they were flowing. I checked the yellow hose and that one was free flowing. Then I checked the white hose and nothing was flowing through it. I removed the throttle body and checked again. Nothing. So, I sprayed the hose connection with brake cleaner. Some black stuff came out but was still not flowing. I found a small wire and tried to stuff it through this little hole on the inside of the throttle body.
Out pops a chunk of black stuff. After I cleared this to where it was free flowing I re-installed the throttle body, cleared the code and it worked! No more P0401!
I hope this helps someone who has tried everything else like I did. BTW this was on an 2003 Evo 8 with 140k miles on it.
Old Jan 15, 2021 | 02:05 PM
Biggiesacks's Avatar
Nice work I'm glad your persistence paid off, and we can all learn from it. Thanks for sharing
Old Jan 15, 2021 | 02:55 PM
BLK_EvIL's Avatar
Nice find!
Mr.Quesada
Aug 17, 2014 01:30 PM
ch53avitech
Jun 23, 2012 08:35 PM
trscOZo3
Feb 4, 2012 08:09 PM
TAIX
Aug 13, 2010 11:16 AM
yesevo
Jul 22, 2006 11:30 AM
