Full Flat-Bottom Undertray EVO
Old Jul 2, 2008 | 09:18 AM
  #91
jid2's Avatar
Balance shafts.... I ask myself that question once a day. I'm not sure yet. If I do remove them then I'll probably have the whole rotating assembly balanced.
Yeah I gave up on using the front jacking position because I couldn't get my jack in there, thus my seam is all mangled like you said. There's no easy way to do it with the car low. I might build inserts for rally style jack stands as well.
Old Jul 2, 2008 | 09:32 AM
  #92
jmartinez1170's Avatar
Wow how does that work. what is used to hold it up like that please explaine
Old Jul 2, 2008 | 09:41 AM
  #93
Vostok 7's Avatar
Still keeping an eye on this thread, hoping to get over there and check out what you're doing.
- Patrick
Old Jul 2, 2008 | 09:47 AM
  #94
CBRD's Avatar
we are doing the same sort of jack mounts...
you have a very nice platform now to make a FUNCTIONAL rear diffuser.... people dont understand that a rear diffuser is really not functional unless its being fed by a flatbottom...
cheers
cb
ill send you some spy shots of ours when i have more done.
Old Jul 2, 2008 | 09:48 AM
  #95
hokiruu's Avatar
Yes, you will need it all balanced for sure, ideally a Fluidampr in addition.
JMartinez, AFAIK ^those^ rally jack points have another tubular piece that go inside fabricated tubular ports into the frame.
My friend has air jacks in his drift S13. They weren't as expensive or hard to install as one might think, but that's another story.
Old Jul 2, 2008 | 10:42 AM
  #96
jid2's Avatar
cheers
cb
Yeah a good rear diffuser is on the list once I finish the motor rebuild project and get some test data behind the other parts. I'll probably prototype something in sheet metal or wet layup carbon and then have the production parts thermoformed.
Your flat bottom should be pretty cool on standoffs like you mentioned in your thread. Just need to make sure the spring rates are high enough to keep it from grounding out or make the standoffs spring loaded so the flat bottom can move up. Kinda like those cheating F1 boys.
Old Jul 5, 2008 | 01:02 AM
  #97
htsai14752's Avatar
price on side skirts
Old Jul 5, 2008 | 08:25 AM
  #98
raiceboi697's Avatar
im really intrested in this and hope it comes together soon
Old Jul 5, 2008 | 09:08 AM
  #99
VincentX's Avatar
Cool.
Old Jul 7, 2008 | 11:22 PM
  #100
supersupra's Avatar
Look into the new "Under floor Air Guide" for the new EVO X from Mitsubishi.
Instead of covering all the under floor, they will install these guides to remove the air from under the car.
Its option #23 in the 08 lancer evo accesories pn MZ575842ex
Old Jul 19, 2008 | 11:56 AM
  #101
jid2's Avatar
Old Jul 21, 2008 | 07:41 AM
  #102
jid2's Avatar
See Above yo.
jid2
120
Oct 18, 2020 08:26 AM
jid2
May 13, 2019 11:37 AM
jid2
Aug 20, 2009 03:35 PM
jid2
71
Oct 16, 2008 11:27 AM
jid2
May 21, 2008 11:53 AM
