Can I simply upgrade HID bulbs?
Old Oct 24, 2003 | 06:44 AM
mayhem's Avatar
Intensity Measurement
From the manual:
1. Set the headlights to high-beam
2. Using a photometer, and following its manufacturer’s instruction manual, measure the headlight center intensity and check to be sure that the limit value is satisfied.
LIMIT: 40,000 cd or more {When a screen is set 18.3 meters ahead of the vehicle}
NOTE: When measuring the intensity, maintain an engine speed of 2000 r/min, with the battery fully charged. There may be special local regulations pertaining to headlight intensity. Be sure to make any adjustments necessary to satisfy such regulations. If an illuminometer is used to make the measurements, convert its values to photometer values by using the following formula.
I=Er2 where:
I=intensity (cd)
E=illumination (lux)
R=distance (m) from headlights to illuminometer
Old Oct 24, 2003 | 08:13 AM
value's Avatar
Those are PIAA 6000K D2R bulbs.
Old Oct 24, 2003 | 09:27 AM
gldenchld's Avatar
How much for the PIAA hids?
Old Oct 24, 2003 | 09:29 AM
Trustz's Avatar
Value: I thought we should use D2S instead of D2R for our project head lights ??
Trustz
Old Oct 24, 2003 | 09:46 AM
value's Avatar
They both can be used the D2S is a drop in the D2R requires mods to the burner housing.
Old Oct 27, 2003 | 06:36 PM
res04's Avatar
PIAA D2S available at www.europeanautosport.com also, no posted price.
Old Oct 31, 2003 | 03:13 AM
zstryder's Avatar
Is it possible to replace the fog bulbs or the high beam (HB3) without taking off the bumper?
Old Oct 31, 2003 | 05:56 AM
kdogg's Avatar
Yes. It takes some hand twisting, and you'll have to remove a small reservoir tank (one bolt) to get to the passanger side highs. BTW, fogs are H11 and Highs are 9005. You can buy both at http://www.europeanautosport.com/evo.htm. They look great .
Old Nov 1, 2003 | 01:03 AM
tlin8's Avatar
The 5.8k AdvancedOptik HID upgrades are soooo nice
Thanks to EuropeanAUTOsport I now have a nice purple shine
Here's the only pic I took that catches the purpleness (it's not easy to capture light):
blackandredgts
Apr 12, 2016 01:59 PM
TxFAkuma
Sep 30, 2015 08:55 AM
JOLLY300
Dec 24, 2013 04:24 PM
tim85851
Nov 28, 2009 02:46 AM
wiretap
Aug 7, 2005 05:19 PM
