Patrick B.'s Evo 9 Update............FINALLY LOL!
Old Nov 20, 2011 | 01:17 PM
  #76
B.J.@ToxicFab's Avatar
Engine bay is looking good Pat!
Old Nov 20, 2011 | 08:32 PM
  #77
yellowevo82's Avatar
looking good...
Old Nov 21, 2011 | 07:51 AM
  #78
PATRICK B.'s Avatar
Thanks guys if all goes well this week I may have a chance to make a couple passes to dial in the tune this weekend.........talk about giving thanks!
Old Nov 21, 2011 | 08:02 AM
  #79
s.e.a.n.'s Avatar
Very nice!
Old Nov 21, 2011 | 08:54 AM
  #80
PATRICK B.'s Avatar
Originally Posted by s.e.a.n.
Very nice!
Appreciate it!
Btw i'm really digging the vids you've posted from "TRC"
Old Nov 21, 2011 | 08:56 AM
  #81
Evosick2332's Avatar
Coming along nicely Pat! Engine bay is looking clean! Cant wait to see more updates from the track day! GL
Old Nov 21, 2011 | 01:40 PM
  #82
PATRICK B.'s Avatar
Thanks joey!
Things took a bit longer than expected but it is what it is.........hope to have it fired up after work tonight I will update the thread with how the new 6766 sounds!
Will be nice to get behind the wheel and make athe pass down the drag strip again.
Old Nov 21, 2011 | 01:44 PM
  #83
Originally Posted by PATRICK B.
Thanks joey!
Yea I hear ya man, when i was doing my build it took longer then expected as well. But in the end its all worth it! I cant wait to hear and read your feedback on the 6766! Im sending mine in soon to get it converted to the 66!
After all dialed in, you might be knocking on the door of a 8 sec pass as well!
Old Nov 21, 2011 | 01:45 PM
  #84
Wheatley's Avatar
Good luck, it should haul the mail!
Old Nov 21, 2011 | 02:06 PM
  #85
R/TErnie's Avatar
Looks good Pat.
Old Nov 21, 2011 | 08:18 PM
  #86
PATRICK B.'s Avatar
Just got back from the shop unfortunately ran into a small issue but a PITA none the less!
Was priming the motor and noticed oil on the back of the block on my scatter shield near the MIVEC banjo fitting.
Checked the hard line and re-torqued the bolt and there was still oil coming from somewhere
Come to find out that one of the hex plugs that goes in the back of the head next to the 14mm bolt on the IM flange was not put back in after the head came back from the machine shop (my fault for not checking).
So i had to pull the IM off and plug it up, clean/dry everything up, and get the IM bolted back up.
Need to double check everything once again tomorrow after work and it should fire right up
Weather forecast says cloudy but 60* at the track on Sat........
Old Nov 21, 2011 | 09:08 PM
  #87
jdowd's Avatar
very nice pat cant wait for this car to be running on its own power, keep me updated if you guys head to the track i wouldnt mind tagging along
derek
Old Nov 22, 2011 | 05:44 PM
  #88
Nelson999's Avatar
Beast!
Old Nov 22, 2011 | 08:56 PM
  #89
Spoolin4g63's Avatar
you get it started pat..?
Old Nov 22, 2011 | 11:56 PM
  #90
Pirana's Avatar
Subs.
