Any Evos with aftermarket stereo systems?
Old May 5, 2004 | 01:36 PM
TwStDeVo's Avatar
what kind of performance effects does adding subs and a box have on 0-60, 1/4 etc? i think i roughly have about 150lbs in the trunk. here is my stereo.
Kenwood Kvt915
Focal interior speakers
Eclipse Ea3422
2 MTX 9500 12s (about 50lbs each)
4cf ported enclosure
MTX 1501d amp
If you have pics of your system please post. thanks!
Old May 5, 2004 | 01:47 PM
cky3396's Avatar
no pics right now but ive got JL 300/4 amp powering infinity perfect 6 in the front and infinity 3way in the rear.. JL 500/1 powering JL 12w6v2.... pioneer 6500 in the dash
really awesome sounds comming from these things
Old May 5, 2004 | 01:53 PM
SterlingEvo's Avatar
150 will be like having an extra person in the car, maybe that weight would help in certain circumstances, adding rear downforce/traction, and hurt in others. I brought over my Sony cassette head unit and 10 disc MP3 changer from my old car, and it sounds great, while only adding about 2 lbs! To be honest, though, I'd rather listen to the engine...
Old May 5, 2004 | 01:56 PM
EVO8 WHOA's Avatar
umm,
ALPINE
M500 amp
MRV-F540 amp
CDA-7995 headunit
MBQUART
Q series 6.5 component system
PSC216 rear coaxial system
Old May 5, 2004 | 03:16 PM
EVOTEXAS's Avatar
you will be .15 seconds slower in the quarter and you will probably handle a little better.
Old May 5, 2004 | 03:23 PM
Ludikraut's Avatar
Originally Posted by EVOTEXAS
... you will probably handle a little better.
How do you figure that?
I'm in the process of replacing the stock setup with:
Alpine 9827 HU
Infinity Kappa speakers (63.5s rear, 60.5s front, Basslink sub)
Speakers and HU are pretty much the same as stock and the basslink at ~20lbs isn't too bad, plus it's easily removeable.
Old May 5, 2004 | 11:28 PM
o00o's Avatar
i got stock components with pioneer deh 860 headunit and a jl audio 10w3v2 with jl audio 1200 amp, sounds great but might consider upgrading stocks eventually
Old May 6, 2004 | 09:25 AM
LilJapnBoy's Avatar
JVC AR3000 headunit
MB Quart RSD 216 component speakers
MB Quart RWE 160 rear speakers
Kenwood 4 ch. amp
I have a Rockford Fosgate 12" bandpass box sub with a RF Punch Amp that I haven't put in because I don't want the weight.
I guess another option would be bazooka tubes instead for lighter weight....
Old May 8, 2004 | 11:12 AM
EVOTEXAS's Avatar
Simple physics. Weight distribution. It's horrible on our EVOs. Suspension could use some work too.
Old May 8, 2004 | 04:30 PM
Mitchubishievo's Avatar
Well it's not that bad and usually no matter what, even if your getting the distribution right, adding more weight will only screw up the way the suspension is set. The rear would probably tend to swing out more if you were to add subs and amps in the back. But, I'm thinking with aftermarket coilovers, the problem would be close to fixed and in that case handling would improve.
Old May 8, 2004 | 10:21 PM
EVOTEXAS's Avatar
Gotta disagree, but it's cool. It's whatever.
Old May 8, 2004 | 11:40 PM
TwStDeVo's Avatar
thanks everyone for your posts, i have a set of JIC coilovers that i will install soon. as for the system, i still like the sound but not sure what effect it had on my performance. my main concern was from standstill to 60 or basically street application. forgot to add that i removed the bottom lining of the trunk and the spare tire to install the box, which pretty much takes up my whole trunk.
Old May 9, 2004 | 01:30 PM
Ludikraut's Avatar
Simple physics dictates that more mass = more inertia, which in turn means that more force will need to be applied to change direction. . . but whatever. Differences of opinion like this is what we have tracks for
Bladed
13
Feb 8, 2008 09:50 PM
TwStDeVo
Jul 9, 2005 06:44 PM
fborg
39
Nov 8, 2004 11:44 AM
djevovii
May 27, 2003 07:08 PM
Event-Horizon
Feb 1, 2003 11:42 AM
