ABS delete kit??
Old Feb 8, 2014, 06:26 PM
  #181
CNOEVO22's Avatar
just finished mine today. i think i need to bleed everything again because my brake pedal goes down pretty far, but we also got alot of snow today so testing really wasn't the greatest. maybe you guys can help me, when the car is off the pedal wont go very far but when its running it presses down further, why is this.
Old Feb 8, 2014, 06:30 PM
  #182
CNOEVO22's Avatar
also stm sells the pressure valves for 40 dollars, and if you go to car-parts.com you can buy a brake master cylindar for a reasonable price. they are used but they put them in category's.
Old Feb 9, 2014, 03:15 PM
  #183
mitsubeastlee's Avatar
I'm 90% sure it has to do with the vacuum the brake booster receives. If the car is off the brake booster does not help with the pressure, when the car is on it makes the job easier for you.
Old Jun 16, 2015, 06:43 AM
  #184
mullen's Avatar
Originally Posted by griceiv
https://www.evolutionm.net/forums/4646956-post5.html
pin 15 of C-122 to ground.
page 90-116 of the evo9 manual.
Has anyone else tried this to see if it works? Just curious Thanks
Old Nov 22, 2015, 01:32 PM
  #185
phrequenc's Avatar
Originally Posted by Wheatley
This is my abs delete firewall, also removed relay plate and wiper wiring hole to the inside of the cabin. Then removed the pad, shaved the unneeded studs and resprayed the bay along with making a quick disconnect milspec harness.
This is what it looks like finished.
I had a rod bend and window the block, having all that extra wiring and unused stuff removed from the bay has made it much easier to pull the engine or anything else from the bay.
that looks amazing man, this is what i would like to do, but i have an 06. and i have not yet figured out how to do this delete properly i would really enjoy the space freed up to mount catch cans and fpr. i noticed you don't have acd or ac, which does clean up the bay but i do plan to keep ac.
any pointers?
Old Dec 11, 2015, 09:23 AM
  #186
Jeepyedo's Avatar
This is so clean and sexy. Gotta give credit where credit is due.
Old Jun 2, 2016, 03:03 PM
  #187
arkangel13's Avatar
Hi Guys
Sorry to bring this thread back from the dead
I own an Evo V and would like to do the ABS delete. I called STM and they asked if my clutch reservoir was different that the one from the brakes and indeed, my clutch reservoir and brake reservoir are different
Do you guys think this will be a problem? Does Evo 8-9 have same clutch & brake reservoir?
Thanks for any thoughts on this
Old Jun 20, 2016, 10:36 AM
  #188
GTijoejoe's Avatar
Originally Posted by arkangel13
Hi Guys
Having different reservoirs will make no different for brake vs clutch hydraulic circuit.
Old Jun 21, 2016, 09:39 AM
  #189
arkangel13's Avatar
Thanks for the response, yes found out I just had to sweap the reservoir and not use the clutch line part
Old Jul 28, 2020, 09:39 AM
  #190
blackline's Avatar
Going to bring this back from the dead. Since one of the lines is discontinued and STM doesn't sell the kit anymore. Any alternatives?
Junkyardspecial
For Sale - Part Outs
May 23, 2017 07:54 PM
BuiltS13
18
May 23, 2016 08:04 AM
RallySport9
Feb 20, 2016 11:24 PM
wrx_ua
Mitsubishi TC-SST Discussion
Feb 20, 2016 08:09 PM
ZanarkO
Feb 19, 2016 02:22 PM
Quick Reply: ABS delete kit??
