ABS delete kit??
Old Aug 14, 2007 | 03:30 PM
jbergmeier's Avatar
ABS delete kit??
any shops going to make a ABS delete kit maybe with instructions to for the do it your self guys??
Old Aug 14, 2007 | 10:20 PM
stimpy's Avatar
Pull the ABS fuse if you really want to remove that nice piece of performance equipment...
I've considered selling my RS on multiple occasions in order to gain ABS.
-Jon
Old Aug 14, 2007 | 10:56 PM
Paul Nelson's Avatar
Can you get the RS brake lines and do a delete?
Old Aug 15, 2007 | 12:16 AM
inco9nito99's Avatar
Evo Abs Ftl!
Old Aug 15, 2007 | 08:04 AM
griceiv's Avatar
you would also need the RS master cylinder (it has the proportioning valves and 4 outlets), and would need to ground the pin in the wire harness that turns on the abs light.
edit: and if you have ACD you'd need to re-route the wheel speed sensor wires.
Old Aug 15, 2007 | 08:52 AM
stimpy's Avatar
I've converted things around on Subarus in the past and what is necessary are parts diagrams and a bit of luck. As an example, the correct part I need to increase the size of my master cylinder from a 15/16" to a 1 1/16" came from a 1994 FWD SVX; only one with the correct fitment for my non-ABS Impreza.
Master cylinders, specifically, are kind of funny since they vary from two ports to four ports, depending upon how the ABS (or lack thereof) needs the inputs. I've never looked at the Mitsubishi parts beyond the fact that there are a ton of hard brake lines that I wouldn't want to have to redo.
-Jon
Old Aug 15, 2007 | 10:58 AM
impreza2darksyd's Avatar
^ +1 ive done the same.
Old Aug 15, 2007 | 11:09 AM
timmiii's Avatar
If you pull the fuse, wouldn't that also affect the distribution system for ABS evos?
Old Aug 15, 2007 | 11:50 AM
griceiv's Avatar
obviously...but real men don't need ABS remember?
Old Aug 15, 2007 | 11:57 AM
fimotorsports's Avatar
i have an RS brake booster and master cylinder if you need it, pm me or send me an aim
Old Aug 15, 2007 | 12:27 PM
stimpy's Avatar
EBD and ABS are integral systems. An RS has neither. The ACD system in the RS still works because it retains the wheel speed sensors. There will obviously be some wiring that is present in the ABS cars that must be rerouted to ensure the signals still pass to all the right locations.
-Jon
Old Oct 12, 2007 | 09:08 PM
DaveK's Avatar
-Jon
I'm looking to do this for my rally/hillclimb project. Has anybody done this 'upgrade' on an ACD equipped car? Are the wheel speed sensors the only things that need to be rewired? Simple as just splicing the correct wires together? If so, can anyone tell me which ones?
I also see that there is a different MC involved that has a proportioning valve in it. If I plan to install a cockpit adjustable proportioning valve, do I still need to source an RS MC?
Thanks!
Dave
Old Nov 15, 2007 | 06:49 AM
timmiii's Avatar
Bump for that guy!! ^^^
Old Mar 12, 2008 | 05:09 PM
bpi's Avatar
bpi
Bump for me too! Looking at either keeping the existing hardware and removing the ABS, or new pedal box, master cylinder, and in-cabin hardlines.
Old Mar 12, 2008 | 05:16 PM
DaveK's Avatar
New pedal box is hard to fit without cutting the firewall. I was going with Wilwood floor mounted pedals in my car, and despite moving my seat back 5-6", there still wasn't enough room for the pedal box with the master cyl attached to the back side.
New plan calls to use the OEM pedals but re-work the connections. As I get more details on my setup, I'll be sure to post in my build up thread (so as not to hijack this one), and if people are interested, I can probably have the guys fab up a few sets of the parts as they fit everything into my car.
Dave
