bump steer... toe in or out
Old Jun 19, 2006 | 10:23 PM
mrfred's Avatar
When the rear suspenion compresses, does it toe in or toe out? I'm also wondering how much bump steer the Whiteline bump steer correction kit removes.
Old Jun 20, 2006 | 04:08 AM
dr.mr's Avatar
Sounds like good questions for ROBI.
Old Jun 20, 2006 | 09:07 AM
mrfred's Avatar
Robert is the only person that knows?
Old Jun 20, 2006 | 09:52 AM
mayhem's Avatar
It toes in.
Old Jun 20, 2006 | 10:06 AM
GTWORX.com's Avatar
Originally Posted by mayhem
It toes in.
Correct. Would be quite dangerous if it toed out.
- Andrew
Old Jun 20, 2006 | 12:03 PM
mrfred's Avatar
- Andrew
That's what I was thinking. Wanted to see someone say it though.
Old Jun 21, 2006 | 08:55 AM
Djazair's Avatar
has anyone verified this with measurement or calculation? is this for stock ride height and/or lowered?
Old Jun 21, 2006 | 08:57 AM
redvolution's Avatar
Yes - stock rear bumpsteer generates toe-in on compression and toe-out on extension. My favorite aspect of the bump-steer kit is the added stability in braking.
Old Jun 21, 2006 | 10:17 AM
mayhem's Avatar
It's built in by the factory to promote some understeer. It's also a design characteristic of a double-arm rear suspension geometry. Toe-in on the outside and toe-out on the inside. I have no calculations to back that up, but I believe it.
My question is, do you get more neg camber under compression in the rear while achieving toe-in at the same time?
Old Jun 21, 2006 | 08:52 PM
mrfred's Avatar
I sent an email to Whiteline and got this response:
"Standard rear suspension increases toe-in in compression. KCA388 [Whiteline rear bumpsteer kit] alters bump steer by approximately +/- 1.1mm/10mm travel. It can be installed to either increase or decrease bump steer."
J!n K@z@mA
19
Mar 8, 2016 11:34 AM
Kento240
15
May 2, 2012 12:42 PM
unvyit
13
Nov 6, 2011 04:43 AM
PoloTurbo
40
Jul 27, 2011 09:40 AM
LancerEVOmann
10
Aug 10, 2005 10:07 AM
