the official VOLK TE37 thread...
Old Feb 18, 2016 | 05:33 AM
  #751
Evo9RS1789's Avatar
Originally Posted by Jp7
Looks fantastic.
Can you take some photos showing how much further (wider) the wheel looks compared the the edges of the body?
Also, what is your suspension setup?
Thank you!
The +15 offset pushes it right to the edge. They are perfectly flush. I will have to roll flat with my current set up. I'll get pictures for you.
I'm on bc/br coils at the moment
Old Feb 27, 2016 | 10:13 AM
  #752
VicVoss's Avatar
Originally Posted by Evo9RS1789
Thank you!
I have a similar suspension and wheel setup, just with 18"s, I was wondering if you have issues with the front tires rubbing against the inner part of the fender well when turning?
Old Feb 27, 2016 | 01:10 PM
  #753
locotalon's Avatar
Does anyone know if this Volks will fit a 2g dsm? they are 18x9 and are on an evo
Old Feb 28, 2016 | 08:57 AM
  #754
Evo9RS1789's Avatar
I do, during full lock, its on the bottom against the "backside" so to speak, of the wheel well. Not sure how to remedy that... Ive seen people beat the frame in with a hammer haha.
Old Mar 4, 2016 | 04:52 PM
  #755
jaime8754's Avatar
I need some advise who have or had Te37 18x9.5+22. Just purchase a brand new set of gloss black for my evo 9. Now the question is... what size of tire should i run? im aware that im going to need fender roll in the rear but am i going to need pull as well??
Old Mar 5, 2016 | 10:12 AM
  #756
Evo9RS1789's Avatar
Depends on how low you are. Realistically a 265 is the best fit for a 9.5" wheel. I had a 255 on a 9.5 and it was sliiiiightly stretching. If you aren't slammed to the ground, a 255 shouldn't give you much issue. If you want to do a lot more of the fender massaging/camber adjustments, you could fit that 265. Totally up to you.
That +22 is fairly aggressive though. If it were me, Id just go with the 255 for the ease of fitment. If you're looking for the most meat possible, the 265 will work... eventually. hahah. It would require lots of work though.
Good luck!
Old Mar 5, 2016 | 09:48 PM
  #757
jaime8754's Avatar
[QUOTE=Evo9RS1789;11585310]Depends on how low you are. Realistically a 265 is the best fit for a 9.5" wheel. I had a 255 on a 9.5 and it was sliiiiightly stretching. If you aren't slammed to the ground, a 255 shouldn't give you much issue. If you want to do a lot more of the fender massaging/camber adjustments, you could fit that 265. Totally up to you.
Good luck![/QUOTE
Im thinking of going with a 255/35r18 tire. anything smaller is going to look way to stretched out.
Old Mar 13, 2016 | 10:05 PM
  #758
fightex's Avatar
Not an Evo but I have TEs on my 4Runner
Old Mar 14, 2016 | 11:22 AM
  #759
Evo9RS1789's Avatar
That looks so sick haha.
You ended up selling those ce28's before I could get rid of mine. I found these 17" te's and I got the idea from your evo!!
Old Mar 15, 2016 | 09:27 PM
  #760
Thrilla's Avatar
Veteran: Army
I'll play. My long gone 2012 C63.
Old Jun 28, 2016 | 08:15 AM
  #761
RZT88's Avatar
Originally Posted by Lambert
I ll try some volks TE37 9,5 / +35...
I think will work fine in my evo...
Hey mate how did these specs end up work out?
Old Jun 28, 2016 | 08:53 PM
  #762
illusin's Avatar
Anyone running the Hyper Green TE's?
Old Jul 8, 2016 | 10:33 PM
  #763
vanvorisdj's Avatar
This is from our Colorado Evo Club. Full Voltex Wide body. Custom painted red with blue pearl. 2.3 Fp zero making 750whp. Shot by me.
Image 7-8-16 at 11.00 PM by David Van Voris, on Flickr
Old Jul 10, 2016 | 08:19 AM
  #764
illusin's Avatar
Evo with hyper green
Old Jul 27, 2016 | 11:17 AM
  #765
etang789's Avatar
Originally Posted by polish_pounder
Ill post pictures once I get them on the car. Cannot wait!
Favorite rim and color on the EVO. Did you have to roll a lot for this +22 setup? How low is your suspension?
