The Brake Rotor, Pad, Line, Fluid, and Duct Thread
Old Dec 31, 2008 | 12:59 PM
  #31
MJ23FE's Avatar
Mike, can you please update the specs for the GiroDisc Magic Pads?
Originally Posted by Girodisc Martin
They have good cold bite but their optimal temp range is 150-850 deg.
Johann @ Girodisc
Thanks!
-Jalal
Old Dec 31, 2008 | 02:28 PM
  #32
MD@'s Avatar
MD@
Originally Posted by chu
On the SS lines, you want to start with something that has DOT approval, as mentioned in the thread. I would recommend something that has a coating on the outside, which serves to protect the stainless lines from rust and so on. I'm using the techna-fits, and they are dot approved and has that protective coating.
Actually, those SS lines are coated to protect the metal braid from abrasion as the suspension strokes.
It's important that attention is paid to the lines so they don't rub on anything - suspension, tires, arms, etc. If the metal braided outer sheath breaks, the sharp edges could cut the inner hose, leading to a line failure. The outer sheath is already stainless, i.e. it's rust resistant inherently.
Old Dec 31, 2008 | 03:38 PM
  #33
Smike's Avatar
Updated! Thanks Jalal.
Old Jan 2, 2009 | 05:19 AM
  #34
SHhhhh's Avatar
Actual 2-piece stock replacement size rotor weights are listed below if you want to add:
FRONT ROTOR WEIGHT (each, lbs)
Stock Brembo 21.35
StopTech 19.35
Racing Brake 19.0
DBA 5000 18.5
Project Mu SCR 18.0
Performance Friction dimpled 17.7
Girodisc slotted 17.4
Girodisc slotted/drilled 17.25
Bear Eradispeed 15.8
REAR ROTOR WEIGHT (each, lbs)
Stock Brembo 14.6
Racing Brake 14.0
StopTech 12.9
Baer Eradispeed 11.66
Girodisc slotted 11.1
Old Jan 2, 2009 | 05:31 AM
  #35
Smike's Avatar
Awesome!!! Done!
Old Jan 2, 2009 | 06:11 AM
  #36
chaotichoax's Avatar
sticky time
Old Jan 2, 2009 | 06:44 AM
  #37
Smike's Avatar
Thank you.
Old Jan 2, 2009 | 07:56 AM
  #38
bsander's Avatar
Awesome write-up. Definately should be a good sticky!
Old Jan 2, 2009 | 02:06 PM
  #39
Protostar1's Avatar
Even if you dont like the idea of 75$ for a liter of fluid, Castrol SRF fluid is THE best brake fluid out there. 590F/518F Dry/Wet.
Also, the ACD makes life difficult for an installer of a ducting kit, but it can be done, I have the AMS kit on my 06.
Here's my write up:
https://www.evolutionm.net/forums/ev...ll-evo-ix.html
Yes, unnecessarily complicated and I partially block my oil cooler for the explicit purpose of symmetry BUUUUT there are a lot of pictures, take it for what its worth
Old Jan 2, 2009 | 02:08 PM
  #40
Protostar1's Avatar
Oh and 'moderator' SmikeEvo? la di da
Old Jan 23, 2009 | 08:22 AM
  #41
o-townFLA's Avatar
SmikeEvo,
you should add a link for the installs of pads, rotors and the like...
Old Jan 23, 2009 | 09:20 AM
  #42
Smike's Avatar
I thought about it. But members can find those in the How-To forum. Unless you have some stellar examples that can be used here.
Old Jan 24, 2009 | 06:22 PM
  #43
Q8_EVO's Avatar
Awesome thread man... thanks
Old Feb 10, 2009 | 03:50 AM
  #44
MrBonus's Avatar
Anyone run Carbotech XP8s for HPDE use?
Old Feb 10, 2009 | 09:49 AM
  #45
SWOLN's Avatar
I've run on the 10's not the 8's at Sebring. Definitely need cooling ducts there. Boiled fluid first run, then bled the brakes, worked for 2 more sessions also using Motul 600.
