Front Hub Replacement
Old Dec 15, 2011 | 06:15 PM
beast66's Avatar
So I took my hub off because the bearings are bad. They are causing my wheel to shake a bit. When I put the hub back on should I grease this who piece.
Old Dec 16, 2011 | 02:07 AM
siceclipse's Avatar
just a little bit of anti seize
Old Dec 16, 2011 | 04:57 AM
chu's Avatar
chu
Yup, just a bit if anti-seize on the spline to help ease install, and future removal.
Old Dec 16, 2011 | 07:08 AM
Piro Fyre's Avatar
Screw a little. Put A LOT of anti-seize on. You don't want this to happen to you.
this was mine. Axle never came out so I ended up replacing the axle and entire hub assy...
Old Dec 16, 2011 | 07:34 AM
4RETECH's Avatar
Yeah, anti seize. My last wheel bearing I did looked like pictured above. I spent a lot of time to get the threads back so the nut would tighten. Not fun
Old Dec 16, 2011 | 12:06 PM
barneyb's Avatar
A thin coating of heavy grease will work too. What you don't want is the splines rusting and rust welding.
Old Dec 16, 2011 | 03:04 PM
honda-guy's Avatar
Piro, ouch..
i put anti-seize on pretty much everything that i remove and reinstall.
Old Dec 17, 2011 | 08:55 PM
barneyb's Avatar
I was in the process of replacing boots on the front axles of my WRX when I encountered a stuck axle in the hub. The end of the axle had a cone shaped depression (actually the lathe center from when it was machined). So, I put the pointy tool on my air hammer in this hole and let it loose. Out came the axle.
Old Dec 17, 2011 | 08:59 PM
evo8dreamcar's Avatar
Always think ahead and just greese it. and anti seeze it. Makes the next time(hopefully not anytime soon) that much easier
Puertokee
May 29, 2021 07:44 AM
Giuna99
Apr 17, 2016 07:35 PM
Squirrel2115
Dec 26, 2015 07:11 PM
dothacker81
Jul 26, 2015 06:55 AM
moamen nosseir
Lancer Tranny/Drivetrain Tech
Sep 9, 2011 05:13 AM
