Evo 9 - leaking front strut and making noise on the right front
Old Jul 16, 2012 | 11:05 AM
emuleiii's Avatar
My Evo 9 at low speed (less than 10mph), every little bumpe and crack in the road gives my front right a pinging sound . I brought it to a repair shop to check it out and they told me to replace the front struts.
They said the car has a leaking strut and is making noise on the right front side.
the shop says the OEM front struts cost $350 each / $700 a pairs and labor cost $315 + 100 alignment . total is 1215 with tax . ( it sounds a bit expensive to me is this price reasonable ?) then I ended up paying $50 for checking ...
I am wondering should I replace the same OEM struts, or to get a better brand or is there anyway to just repair my current struts ? is it a common problem ? any advise would be greatly appreciated .
Old Jul 16, 2012 | 11:19 AM
Smike's Avatar
Strut is blown.
Do you have an Evo 9 MR? If not, no - KYBs are not rebuildable.
Search the For Sale forum here for a set of used KYBs. Should be $300 for all 4 (less for just front pair). Find a new shop. $315 for a 2 hour job is way off.
Better: Bilstein HD struts (new) or used set of Bilstein MRs. Both are rebuildable. Cost more up front.
Old Jul 16, 2012 | 11:35 AM
emuleiii's Avatar
EVO 9 not MR . so the OEM is KYB ? how come the shop told me OEM cost $350 each and KYB cost 230 each ...
Old Jul 16, 2012 | 11:40 AM
Smike's Avatar
Shop has no idea what an Evo is.
Old Jul 17, 2012 | 06:09 AM
emuleiii's Avatar
Do I need to replace spring as well ? or the spring need to be adjusted to fit Bilstein HD struts ?
Old Jul 17, 2012 | 08:13 AM
Smike's Avatar
Should not have to replace the spring.
Old Jul 17, 2012 | 08:23 AM
emuleiii's Avatar
Thank you for your advises
Old Jul 18, 2012 | 12:58 PM
emuleiii's Avatar
I just placed an order of a pairs of front Bilstein HD Struts. Does it matter if I am using Bilstein HD Struts in the front and keeping the KYB in the rear ? ( since the rear struts are still good )
Old Jul 19, 2012 | 04:29 AM
Smike's Avatar
Rears wont be that far along to they need to be replaced also. For daily driving, wont make a big difference if keeping the OEM springs on all 4 corners.
I'd start saving up for the rears.
MrAWD
Sep 19, 2016 08:39 AM
Jcusco407
18
Apr 9, 2013 05:38 PM
fcapistran
Northwest Region
15
Nov 15, 2010 10:14 AM
kmcconn9
Apr 29, 2007 04:09 PM
4g63_24
Jul 23, 2006 05:12 PM
