brakes squealing/squeaking
Old Sep 28, 2012 | 12:02 PM
dizzle06ix's Avatar
In february i got new slotted rotors and pads on my evo ix. I didnt really drive the car till about july, it was driven every so often, not ignored completely. but when i come to a stop, i get a extremely annoying and high pitched squeak/squeal, i have pulled my wheels and cleaned the outside face of the rotor with brake clean and wiped it clear of debri. That worked for a few minutes, then it was back to the horrific squealing. i can put pictures up, there is no ridges yet on the rotor, what could be the cause? I didnt clean the back side because the caliper and brake shield was on..
Old Sep 28, 2012 | 12:41 PM
legato's Avatar
Could be that the brakes weren't bedded properly?
Old Sep 28, 2012 | 12:47 PM
dizzle06ix's Avatar
Could be... :/ I had a local shop install them because i was out of town.
Still fairly knew to evos.. is there a way to make sure they are bedded properly?
Old Sep 28, 2012 | 12:59 PM
jtanner_'s Avatar
What brand of brake pads are they? Certain pads are notorious for squealing on our cars...
Old Sep 28, 2012 | 01:15 PM
dizzle06ix's Avatar
i'm searching for the reciept now. I can't seem to find it but am still looking.
Old Sep 28, 2012 | 01:18 PM
What the others have said & this:
Are the stock Brembo angled shims in-place, front & rear. They do a lot IMO to prevent squealing on non track type pads
Old Sep 28, 2012 | 01:36 PM
dizzle06ix's Avatar
Easiest way to tell?.. Still searching for that danged reciept.. :/
Old Sep 28, 2012 | 01:51 PM
dizzle06ix's Avatar
Well I found my original quote, but I want to say that he changed one of the pads on me last minute.. The quote is for Powerslot Slotted rotors all around, Performance Friction Metallic Z Brake Pads Front, and Hawk HPS rear pads.
Old Sep 28, 2012 | 02:18 PM
CurseDSM's Avatar
anti squeel is your friend.
Old Sep 29, 2012 | 06:24 AM
If you pull the wheels, you can see them using a flash light & inspecting the top of the caliper & pads
Old Sep 29, 2012 | 04:49 PM
fnlygotboost's Avatar
Unfortunately sometimes these brakes just squeel all the time - had an issue with it myself. The stock brembos and pads were horrible, upgraded to DBA 5000's on the front with hawk pads, helped a bunch but not completely.
Old Sep 29, 2012 | 11:03 PM
jtanner_'s Avatar
I found my brakes started to squeal like crazy once I upgraded to HPS/HP+ on my powerslots...
Old Sep 30, 2012 | 07:21 AM
Accountant's Avatar
So what brand should I go for that won't squeal ? I'm new and already share the same problem. Currently using hawks brake pads
4g63xawd
62
Jan 6, 2016 03:25 AM
Evodetailer123
Apr 14, 2015 02:37 PM
luckybull
13
Mar 20, 2013 10:30 PM
Jush
12
Apr 29, 2012 08:08 AM
raytrix
21
Dec 16, 2009 09:53 PM
