Spring Rate Chart
Old May 4, 2006 | 10:12 AM
  #226
JohnBradley's Avatar
H&R street coilover..............457lbs(8.2K).....457lbs(8.2. K)....Adjustable
Dampening not adjustable, but higher spring rate window up to 9.2k
Old May 4, 2006 | 06:45 PM
  #227
Wangracing's Avatar
KW Variant 3's std spring rate for the evo... (At leats thats what they would come with in Australia)
90N (9kg) (500lb) Front Springs
70N (7kg) (390lb) Rear Springs
Although they can be special ordered with a wide range of spring rates.
Old May 18, 2006 | 11:19 AM
  #228
redvolution's Avatar
90N is NOT 9kg. N/mm can be converted to kg/mm by dividing N/mm by the gravitational constant: 9.80665
In this example, 90N/mm = 9.18kg/mm
Old May 18, 2006 | 04:22 PM
  #229
Wangracing's Avatar
Thanks for clearing that up
Old Jun 2, 2006 | 09:30 PM
  #230
ReSin's Avatar
Bilstein PSS9's 430/145 lbs......460 lbs...adjustable
Dennis
Old Jun 8, 2006 | 08:30 AM
  #231
lemansz's Avatar
VERY helpful my 05 had a set of hotchkis sprinsg that i DID not like.
Old Jun 16, 2006 | 10:08 PM
  #232
mrfred's Avatar
How about adding Swift springs to the lowering spring chart? 270f/314r, -1.4f/-0.8r (Values are per Swift website. Standard and MR springs have the same rate and drop).
Could also add Works drop springs for the MR too. I haven't found the rate, but the claimed drop is 0.9" front and rear.
Old Jul 13, 2006 | 12:40 PM
  #233
hokiruu's Avatar
WORKS rates?
Old Aug 14, 2006 | 07:57 AM
  #234
hokiruu's Avatar
Probably a repost, but what about Buddy Club?
Old Aug 22, 2006 | 06:41 PM
  #235
ernald711's Avatar
good info. gotta update with with the swift spring rates.
Old Aug 26, 2006 | 07:44 PM
  #236
SHhhhh's Avatar
anyone have any info on the BC Racing dampers?
http://www.importimageracing.com/pro...oducts_id=1269
Old Aug 29, 2006 | 02:22 PM
  #237
occultworks's Avatar
Megan Racing springs: 280lbs. front / 350lbs. rear -2" front / -1.9" rear
Old Aug 31, 2006 | 03:01 AM
  #238
troe666's Avatar
just bought some new Evo 9 Tein SS coilovers.
f 390 r 340
drop is up to -56mm on the front, and up to -41mm on the rear. Assuming you have no pillowball tops.
if you have Tein pillow ball tops you'll get less total adjustment to the tune of about 10-11mm.
Looking forward to this mod. The spring rates are exactly what I was looking for, as well as the adjustable range. Very nice. Tein gear is very successful over in Australia, its very streetable yet seems great for track too.
Sorry I know you already have Tein SS on your list but the figures are ever so slightly different and this is for Evo 9 if you ever make a spring rate chart for that,
Cheers - oh and this thread ROCKS!!!!! Thanks guys.
Trav
Old Sep 5, 2006 | 06:44 AM
  #239
yosolo's Avatar
Buddy Racing Spec Damper (560Lbs)10k F (560Lbs)10k R adjustable
Old Sep 5, 2006 | 06:48 AM
  #240
hokiruu's Avatar
THANKS!!! Can we please add this to the front page?
