Spring Rate Chart
Old Mar 5, 2007 | 11:46 PM
  #256
Mr. Furley's Avatar
Anyone recommend lowering springs?
Old Mar 19, 2007 | 11:02 AM
  #257
FiftyFive's Avatar
Megan springs 280F 350R -2.0" Front, -1.9" Rear
Old Mar 21, 2007 | 05:17 AM
  #258
MyEvoDream's Avatar
Hotchkis anyone....?
Old Mar 21, 2007 | 05:23 AM
  #259
MyEvoDream's Avatar
Hotchkis- Front 1.5" Drop 195 lb/in Rear 1" Drop 275 lb/in
Old Apr 24, 2007 | 12:21 PM
  #260
Sodré's Avatar
Hi guys,
I from Brazil, and the streets here is not good...
I realy want more confortable in my Evo...
please help me
Thank you
Old May 8, 2007 | 09:05 PM
  #261
MrSmith's Avatar
The Hotchkins arent bad.
Old May 13, 2007 | 08:40 PM
  #262
texasevo's Avatar
I just installed some Tein Flex coilovers this weekend. The ride is very stiff now. I'm not liking them very much. I adjusted the dampening to the softest level and its still a bumpy ride. The adjustability of these is very nice though.
Old May 15, 2007 | 08:19 AM
  #263
Michael K.'s Avatar
Originally Posted by tkeirin
based on this chart, i feel that my tein flex is stiffer than 9kg/8kg.
i've called tein and they said the spring rates for tein flex is 12kg/10kg.
??? For the MonoFlex (wich is normally same springs rates than the old Flex), Tein anounce 9kg for front and 7kg for rear, with no choice of other rates (possible with special order).
12kg and 10kg (14 and 12 at your choice) are rates of the Super Racing kit.
Same feeling, but I'm disapointed by the range of adjustability, not wide enough.
Otherwise, they are not stiff enough on the track (the principal use of my Evo), so I plan to sell them and choose the Super Racing...
Old May 17, 2007 | 05:56 PM
  #264
cfdfireman1's Avatar
comfort
Originally Posted by Sodré
Hi guys,
please help me
Thank you
Get a set of used Bilsteins from an MR.
Old May 18, 2007 | 01:56 AM
  #265
machron1's Avatar
^^ And some different tires...all-seasons will give you a lot better ride on the rough stuff...
Old May 30, 2007 | 03:48 PM
  #266
jhall651's Avatar
ok so i installed the tein s-techs on my evo 8 and the ride seems softer than stock. the reason i say that is at higher speeds when i do like a sharp lane change i have this body roll/recoil type effect and i had someone tell me its because my springs and not as stiff as stock. has anyone else ever had this problem? when i do this it makes my stearing seem a bit lose. anyone know about this. also if i get the tein coilovers will a normal alignment shop be able to re-elign it?
Old May 30, 2007 | 03:52 PM
  #267
mrfred's Avatar
With the almost universal bashing that Tein S-Techs get on this forum, I'm always surprised at how many people buy/install these things.
Old May 30, 2007 | 05:22 PM
  #268
point&shoot's Avatar
Another Report on the Stance Coilovers
Here's my second impression of the Stance GR+ coilovers, after using them in three auto-crosses. In the first autocross, I didn't have the alignment I asked for (they gave me -1.6 camber in the rear, when I asked for -1.25).
After fixing that, I did much better in the second autocross, and the suspension felt wonderfully responsive and glued to the road. I had the dampers set to 6 clicks from full stiff, both front and rear, as recommend by Stance, instead of full stiff, as in the first event. But the car was still understeering on turn-in, and slightly understeering in steady-state cornering.
In the third event, I tried stiffening the rear dampers (4-clicks from full stiff) and softening the front dampers (8-clicks from full stiff). Also, I increased the pressure differential to 33F/38R. Previously I had been using only a 3 lb differential. (Note that I'm on the stock rear sway bar.) This immediately improved my times by .8 seconds, in an 80 -econd course. The car now turns in eagerly, although the slight steady-state cornering understeer is still there, and I'll fix that with a stiffer rear sway bar.
Needless to say, I'm incredibly pleased with these coilovers, especially considering they were only $1200 direct from the factory!
Old Jun 2, 2007 | 11:33 AM
  #269
kiley_sean's Avatar
BC racing 46mm coilover review:
https://www.evolutionm.net/forums/sh...d.php?t=239615
Old Jun 5, 2007 | 11:35 AM
  #270
boomn29's Avatar
Me too dude.
