Where do I buy struts?
Old Dec 4, 2013 | 10:18 AM
[GBU]Moon's Avatar
Almost immediately I after I purchased my Evo, I installed the BC Racing coilover set. While I'm sure this set is nice in some areas, in Wisconsin it lasts about 1-2 years tops before the salt completely corrodes everything. I tried another aftermarket set and found the same result so I finally wised up and went back to stock. I currently run stock suspension with aftermarket springs and it's perfect. Starting about a week ago, the front corner started dipping more than the rest of the car, it's quite bouncy too. I assume I need new struts, right? I'd like to stick with OEM unless someone can recommend a good reason for switching, an alternative would have to be OK in the snow and salt.
I found these, but I'm not sure which would fit my 2003 Evolution VIII. Is this a good place to buy them?
http://www.oemmitsubishiparts.com/pa...?siteid=214331
Strut Front Lancer: $52.91
Strut Front Lancer w/ Turbo: $247.22
I assume this means the w/ Turbo is the Evolution? The website isn't very specific. Figures it would be five times more expensive :P
Thanks in advance!
Old Dec 4, 2013 | 12:13 PM
barneyb's Avatar
I'd say it is very likely you are correct. I remember when I wrecked a strut on my DSM and a new one from Advance Auto was $25. BTW, if one is bad I don't know of any reason to replace two. These struts seem to spontaneously fail rather than wearing out.
Old Dec 4, 2013 | 12:14 PM
[GBU]Moon's Avatar
If they are inexpensive I'll replace all four. Thanks for the tip, I'll drop by Advanced Auto, see what they have.
Old Dec 4, 2013 | 04:25 PM
barneyb's Avatar
Lots of luck with that!
Old Dec 23, 2013 | 08:41 AM
Discospeed's Avatar
Hey man i dont know what year evo you have but ive got a set of evo 9 struts with 7k on them that i was going to post up for sale soon. Pm me if you intrested. Thanks
-Tony
Old Dec 28, 2013 | 08:40 AM
fwd_josh's Avatar
Also, if you want to stay on coil overs, look in to the KW's. They have a stainless steel option.
Old Apr 7, 2014 | 06:42 PM
[GBU]Moon's Avatar
-Tony
Awe, bummer, didn't see this post until after I purchased the set from Advanced Auto. So check this out.. not only did they give me LANCER struts (yes, when I picked them up I said, "Evo, EVOLUTION, not just Lancer" and they said yes yes yes). Surprise, they were very not for an Evolution. I ended up saying 'to hell with it' and ordered OEM replacements for like ~$300 per corner. Oh well, no more rotten aftermarket junk.
aptok14
Jan 27, 2017 06:28 PM
zztt
Apr 23, 2014 06:31 AM
zztt
Lancer Engine Tech
15
Apr 14, 2014 04:39 PM
ninj4sevo8
Jul 4, 2011 03:15 PM
Blacksheepdj
Aug 27, 2007 10:13 PM
