Is it good or bad to mix and match pads and rotors for autocross?
I was wondering if anyone has any real world feedback or technical information on whether it's a good or bad idea to use different pads and rotors on the front brakes vs the backs when autocrossing.
For example, I currently have Stoptech pads and rotors on the rears and OEM or "OEM style" pads and rotors on the fronts. I really want to upgrade the fronts before I do any events this year, but should I get Stoptechs since that's what I have on the rears or go with something else like DBA 4000s and Ferodo pads?
Will using a different setup on the front vs the back cause uneven braking?
Any feedback is greatly appreciated.
Mixing rotors isn't a huge deal. But you don't want the front and rear pads too far apart. Which stoptechs are currently on the rear?
That's a relatively small difference in pad compound. Where as if the OP has Stoptech street performance pads on the rear, and puts DS2500's on the front, it will be a fairly significant difference in how each end of the car works on the brakes..
The reason my setup is the way that it is is because when I got this car about 6 months ago the front brakes were OK (mechanically) but the rears were toast. I originally wanted to upgrade all 4 at the same time but financially it didn't work out, so I decided to get the rears done asap and waited to get the fronts done when I had some more cash. I'm also not 100% the fronts are OEM. The shop that did the rears thought they might just be a standard pad from Autozone or something. They seem to perform fine on the street but I definitely want to get them switched out before I do any racing.
oftheheavens
12
Apr 27, 2011 12:42 PM
wiredspeed.com
10
Dec 14, 2004 12:05 PM
Tak555
Aug 13, 2004 12:12 PM
JoshGrisham2002
May 23, 2002 04:14 AM
