S2k wheels on evo?
Old Oct 20, 2016 | 01:02 PM
Egyptian_b00st's Avatar
S2k wheels on evo?
Hey guys, so i been makin some research about drag setup u can use while keeping my stock brembos, so decided to go with 16X7 rim. The issue was they would require spacers with 40mm offset. I looked into the rear wheels of s2k which r 16x7.5 +65. Has anyone ran these? Or ran into problems fitting these? Thanks
Old Oct 20, 2016 | 01:24 PM
Very unlikely they would fit over the front Brembos no matter what spacer is used
Check out this thread here:
https://www.evolutionm.net/forums/dr...l-fit-evo.html
Old Oct 20, 2016 | 05:05 PM
I read that thread and concluded that u need about 60mm to clear the brakes. People always use 40 offset and 20mm spacers, what would be the difference if used 65mm offset?
Old Oct 20, 2016 | 06:16 PM
16 inchers are out of my skill set & dont want to steer you wrong
Did a search & there are many threads of S2K's running EvO wheels but couldnt find any examples the other way around
Old Oct 20, 2016 | 07:14 PM
Same here lol looks like no one did or whoever did it didnt share it. Idk if i wanna be the experiment here lol
Old Nov 16, 2016 | 07:45 PM
No one thought or tried that?
Old Nov 17, 2016 | 07:24 AM
llDemonll's Avatar
running a spacer that large is probably not a great idea for a drag setup...go with tried-and-true rx7 wheels
Old Nov 17, 2016 | 12:23 PM
I dont wanna run spacer at all, im wondering if it would clear the brakes without a spacers
Old Nov 18, 2016 | 07:54 AM
llDemonll's Avatar
s2k wheels? good lord no. look at your stock wheels, those are +38 offset with a HUGE amount of space behind the wheel spokes. a stock s2k wheel will sit about 1" inward on the BACK of the wheel, and the face of the wheel will be 1.5" inward from the stock evo wheels.
and absolutely no chance those will clear the brakes. in the rear the might clear with a 15mm spacer, maybe larger, but the front will need a 30mm spacer at least
Old Nov 18, 2016 | 08:00 AM
kyoo's Avatar
yea I envy the spacing s2k's have
s2kguy
36
Aug 27, 2004 06:37 AM
evoaction05
29
Aug 19, 2004 09:48 AM
crash77
25
Mar 12, 2004 11:26 AM
Static
Nov 23, 2003 10:26 AM
DB8GSR
Jun 6, 2002 11:34 PM
