CBRD Tune ECUFlash
Old Jan 16, 2009 | 08:26 AM
steinvb12's Avatar
Originally Posted by CBRD
the CEL i believe i airflow limiter related im working on it now... testing on my car tonight.. (using cobb software)....
i tune each car based on mods.... this car has stock fmic etc.... so im not being overly aggressive
cb
I can't wait until you guys get some Cobb software and start really tuning these X's. Then I think you will see some real progress.
I may just have to come down for a tune in the spring...
Old Jan 16, 2009 | 08:29 AM
CBRD's Avatar
we have the cobb software, and thats what im using on my own car...
playing with a 20psi actuator right now
cheers
cb
Old Jan 16, 2009 | 08:52 AM
davidiii's Avatar
cheers
cb
hey chad its dave..ive been talking to you via email for a bit- cant wait till see your results with the acutator! also i cant wait to get my car down to you guys for my cobb protune! talk to u soon
Old Jan 16, 2009 | 09:04 AM
Sean@Iveytune's Avatar
So Ecuflash is out for the 10 now? Amazing, I didn't know this. Where is the SW?
Sean
Old Jan 16, 2009 | 03:41 PM
Papi4baby's Avatar
Can't wait for my Pro Tune from CBRD
Old Jan 16, 2009 | 05:06 PM
Clark_Kent's Avatar
I am looking to see some results from CBRD with the Cobb software. Good work!
Old Jan 16, 2009 | 08:49 PM
davidiii's Avatar
+1...ill have my accessport in my hands next friday- anytime after that when they have the time im looking to get into their shop! trust me ill do a FULL write up and post dyno graphs!
Old Jan 16, 2009 | 08:59 PM
Clark_Kent's Avatar
^Thanks man. I'm looking forward to the information.
Old Jan 17, 2009 | 08:40 AM
CBRD's Avatar
did some testing with cobb stuff yesterday...
interesting results... more to come...
we are going to really dive into the X products shortly (in addition to our fmic and radiator, and some bolt on turbos)
cb
Old Jan 17, 2009 | 11:50 AM
STi2EvoX's Avatar
Originally Posted by gunzo
Bryan .. we need to talk
I'm still wondering why the tables #1-3 work for me and not for you..
DARE to try something DIFFERENT ???
Which tables are these exactly?
lol...
yeah its the torque limiter tables i believe... still tinkering with them..
some cars ive had the issue, some i havent
im working with JESTR (and im going to chat more with bryan) for a good solution
cb
PS the mivec tables were adjusted.
Originally Posted by mad_VIII
Sound like that dyno reads close to the dyno4mance heart breaker... Good numbers, good work CBRD.
Yes, everyone that tunes 10's has had to "deal" with the trustful airflow checks tables that lead to the limp mode. They just need to figure out the load you are running AFTER the tune and setup the tables accordingly.
Are the MAF reference tables (or airflow check tables) that are used for throwing the car into limp mode the same tables that chad is refering to as "torque limiter tables," just a different name? Also, are these the same tables that are used for throwing the ASC code that some people have been getting with tunes? BTW, I am almost ready for my tune (sorry it's taken so long, times have been tough lately ) When I get up there, you gotta take me for a ride in your X, 'cause that dominator 2 sounds badass! Thanks man.
Old Jan 17, 2009 | 01:17 PM
CBRD's Avatar
compare the airflow and torque limiter tables... 4 of each..
cb
Old Jan 17, 2009 | 02:37 PM
STi2EvoX's Avatar
Hmm, interesting. So what are the torque limiter tables based on? What do they reference to calculate? Is it load, map readings, maf readings, does it cross reference the maf airflow check tables, or a combination of these? Thanks for any info.
Old Jan 17, 2009 | 02:40 PM
Clark_Kent's Avatar
cb
Excellent. Please post some results as soon as they are ready. I am interested in the products as well, FMIC mainly.
Old Jan 17, 2009 | 05:13 PM
SiC's Avatar
SiC
cb
I think it's actually 3 of each and the 4th is actually a reference table of some sort (no need for adjustments). Those are some weird tables, Airflow & Torque both share the same scale & values. I've seen shops here that use ECUTek and just raise the values by around 10% and some shops that raise it 40% at WOT 2500-8000 RPM.
To each their own, but I have yet to run into any problems by raising the values high. Also, if you look at the values for 5MT and SST, they are different from the factory, even the reference table.
Old Jan 17, 2009 | 05:22 PM
STi2EvoX's Avatar
So what do these tables use to calculate? Are they based on load, airflow over the maf, what? Could you post pics of the tables? That would be great, if you don't mind.
