CBRD BB-X - E85 - +83 whp peak!
Old Jan 27, 2010 | 07:22 AM
  #76
CBRD's Avatar
Ive yet to have a 10 make awesome torque...
That's what I was searching for in my quest for our evo X turbo, and I tried and tried... I still have a X turbo sitting here with a Titanium turbine/shaft etc... but it wasnt fantastic...
the 3076R from garrett was not good at all, decent PEAK power but lost like 30 wtq from stock and spooled 1200 rpm later with the .94 hotside.. we then dropped to the .7X hotside and it surged more than anything ive ever experienced....
I then tried to get a combination with minimal spool loss 400-750 rpm.... and would keep torque close to the stock turbo (with the boost cranked up) and still pick up 40-80whp up top on pump gas.
cb
Old Jan 27, 2010 | 07:23 AM
  #77
murlo26's Avatar
I am pretty sure we will see some good torque monster cars from this turbo once people start boosting 32ish+ on e85/race.
Old Jan 27, 2010 | 07:56 AM
  #78
CBRD's Avatar
I think with catless cars, good cams and mivec mapping, with all the trimmings it will do what people expect
cb
Old Jan 27, 2010 | 11:42 AM
  #79
mlomker's Avatar
Originally Posted by Mellon Tuning
you don't need an upgraded FPR
Some people are doing it to up the base on DW1000's. I looked into it and decided to just get a set of the big ID2000's instead. The Walbros don't like to function at 80+psi anyway. If mid-size plug-and-play injectors were offered then I'd agree with you but those of us on E85 are in a bit of a pickle...it's either an fpr or $900 injectors.
Old Jan 27, 2010 | 11:49 AM
  #80
penthouse's Avatar
iam on e85, we dont need afpr or fuel rail what so ever, just two fuel pump and 1200cc and up . And stock fuel lines too.
Old Jan 27, 2010 | 11:50 AM
  #81
mlomker's Avatar
My point exactly. Nobody makes a plug-and-play injector that is 1200cc. You have to jump from DW1000's all the way to the ID2000's.
I'm not going to be the first guy to install the FIC 1250 w/adapters and see if they tune and idle okay. I haven't seen any dyno charts posted yet that use them.
Old Jan 27, 2010 | 11:54 AM
  #82
murlo26's Avatar
We are talking Evo X's here not your 8. No one wants to put in ****ty low impedance injectors that aren't really made for the X. We prefer the sweet drop in ones that are guaranteed to work well on the X and are high impedance. The only ones out are either DW1000's which almost everyone runs or ID2000's. Well there are some big TIAG and FIC ones too but those are all above 2000cc anyways too.
Old Jan 27, 2010 | 12:04 PM
  #83
penthouse's Avatar
well there u go, just put in an id2000 . have more head room
Old Jan 27, 2010 | 12:08 PM
  #84
mlomker's Avatar
I'm personally going to go that way, I was just trying to explain why someone might want to overdrive the DW1000's using a $200 fpr setup rather than spend $900 on a set of injectors.
Old Jan 27, 2010 | 12:11 PM
  #85
penthouse's Avatar
oh gotcha mlomker
Old Jan 27, 2010 | 12:37 PM
  #86
GST Motorsports's Avatar
Wow good ol' evom going off topic. Why are there irrelevant stock turbo street software graphs from another vendor in this thread?? - Bryan
Old Jan 27, 2010 | 12:46 PM
  #87
Noize's Avatar
EvoM Administrator
Cleaned.
Injector stuff OK, but OT junk edited.
Please keep other vendor graphs out of OP's results thread.
Old Jan 27, 2010 | 12:48 PM
  #88
Mellon Racing's Avatar
- Bryan
because we were having a discussion about tq on the X and this particular turbo. I was merely sharing data to see if the spread between hp and tq were similar with other larger turbos vs stock. Sorry if I stepped on your toes.
Old Jan 27, 2010 | 12:50 PM
  #89
Noize's Avatar
EvoM Administrator
Please start your own thread. We can keep things streamlined a lot better that way.
Old Jan 27, 2010 | 12:55 PM
  #90
evox44's Avatar
Low torque + High WHP numbers, this might be perfect for the SST.
If the BBK BIG can now do something like 400wtq and 550whp-600whp that would be out of class!
