tscomptuned 08 GSR - 360hp/375tq
Old Apr 24, 2012 | 03:03 PM
murlo26's Avatar
Originally Posted by tscompusa
Murlo is that e85? id just give it alittle more wgdc downlow to fill in that low curve a bit more and you should smooth out your spool curve. we had a curve like that also until i slowly filled it in with wgdc.
so 350-360 is the norm for this kind of modded evo X on 93?
E85 yes, very conservative tune actually. I didn't want kill mode as I want motor #3 to make it a few years.
350-360 is the norm on a pump gas stock turbo with or without cams. Unless you push it to like 30psi on pump that is where you should be. As I said cams don't help a ton.
On E85, cams, stock turbo and 32psi I only made 400whp...the stock X turbo is just small and doesn't do 8/9 numbers. But it sure does spool fast
Old Apr 24, 2012 | 04:17 PM
prowakeskater's Avatar
yeah it seems these s2's really don't do too much. Im glad I didn't pay for them
Old Apr 26, 2012 | 03:43 AM
this car pulls nearly as hard as my 8. i didn't think that was possible on this platform
Old Apr 26, 2012 | 07:43 AM
murlo26's Avatar
The car makes as much or more power than the 8/9's. The problem is you need to make a decent amount more to feel the same pull with the extra weight.
TheMyth
Jan 25, 2018 06:23 PM
prowakeskater
For Sale - Part Outs
13
Jun 22, 2012 03:22 PM
prowakeskater
May 28, 2012 01:26 PM
prowakeskater
May 7, 2011 10:02 PM
prowakeskater
Apr 25, 2011 05:35 AM
