ETS GTX3076R Turbo Kit E85 Tune
Hey guys wanted to share another nice set up on another evo X owned by Jeremiah Mcgree in the good ol SOUTH CAROLINA! He DD's this bad boy, but no track times...yet.
Shift Fast Motorsports built Evo X
2.1 sleeved block
9:1 with Manley pistons
Manley “I” beams
Shift Fast Motorsport Stage 2 port and polish head
274 GSC s2 Cams
ETS GTX3076R turbo kit
Id 1000 injectors (60 psi fuel pressure)
ETS intercooler kit
Stock Map Sensor
EBC 3 port
Full blown double pumper with Walbaro 255’s
Exedy twin disk
31 PSI tapering down to 24
E85
2.1 sleeved block
Manley “I” beams
274 GSC s2 Cams
ETS intercooler kit
Stock Map Sensor
EBC 3 port
Exedy twin disk
E85
After going back through my logs it seems to hit full at 4k, I did use a slower boost strategy because it felt like it had a little clutch slip in the higher gears when you loaded it up and severe taper for the IDCs to stay "safe". Over all the car does generally hit peak pressure at 4-4100rpm. Normally I would run a tighter wgdc to bring it in faster.
I will say that the GTX30r is not on my list of choice turbos for the X... lol
Also the id1ks were maxed out at this point. Even at high base they can no longer keep up and when I tried to run less taper I saw static IDCs
SpeedI2acerX
13
Nov 4, 2016 01:40 PM
newMRevoNyne
13
Jan 29, 2016 04:32 AM
TopLevelPerformance
19
Jul 18, 2012 11:03 PM
