2011 EvoX GSR SST EFR8374 External\Wg 585WHP
Old Mar 9, 2016, 01:11 PM
0uch.!'s Avatar
Guys from RealPerfomance ( Moscow) build this car with specs:
1. 2.0 engine with stock sleeves
2. BW EFR 8374 1.05 turbo with 2 external Wastegates
3. 3" exhaust with Invidia Q300 catback
4. Manley H-beam rods
5. Mahle pistons
6. Kelford 214-B cams
7. ID 2000cc injectors
8. Custom fuel system
9. 102mm intake from air filter to turbo
10. 3.5" ETS intercooler
11. Omni4bar MAP sensor
12. Stock ECU
13. 98 octane
The main quetions was - will the clutch be able to withstand a design horsepower ?!?! And the guys brought the gearbox to us .... Then we fixed problem with sensor of one of shift forks like this :
And made custom durable 5disc clutches with heavy steel plates:
Then they mounted gearbox in the car and took her on a superflow dyno ..
On the dyno , the car showed on 4th gear this:
But when it came to gear shift , the clutch sliped ....
Again the guys took the gearbox and brought it to us. Then we made custom 6 disc clutches. It looks like this
Then they again go to the dyno and try it and that's what happened:
Sport mode inside
Sport mode outside
S-sport mode inside
S-sport mode outside
P.S. Now the clutches can easily handle this power and soon we will try to add horsepower and torque to get to know her limit
Old Mar 9, 2016, 10:45 PM
MNC5's Avatar
Nice job. What brand clutches are you using
Old Mar 10, 2016, 12:34 AM
0uch.!'s Avatar
Thx, we using self made clutches .
Old Mar 10, 2016, 10:24 PM
MNC5's Avatar
And I thought you were a serious guy before this ***ery. Please explain "self made" like at work? or in your kitchen?
Old Mar 10, 2016, 10:49 PM
0uch.!'s Avatar
Not in the kitchen of course ))) We made steel plates and tune clutch hub in the factory . For our clutches we use oem friction plates , or aftermarket frictions plates ..
That's the magic ))
Old Apr 8, 2016, 12:38 AM
0uch.!'s Avatar
One more video with accel , soon this car will tune on 114octane fuel ))
Old Apr 8, 2016, 11:44 AM
KVandy15's Avatar
this is pretty awesome, good job.
Old Apr 9, 2016, 04:50 AM
MNC5's Avatar
Looks like fun, nice job with the SST holding 585whp too. What boost # is it @ on 98 octane
Old Apr 9, 2016, 08:19 AM
0uch.!'s Avatar
30psi in the midle and 34 psi to high rpm's.
P.S. Our 98octane like 92 yours )))
0uch.!
Evo X Dyno Results
27
Feb 6, 2015 06:43 AM
R/TErnie
Jun 12, 2014 07:56 AM
Grimgrak
Jun 5, 2014 03:18 PM
project_skyline
Mar 16, 2014 11:12 AM
Quick Reply: 2011 EvoX GSR SST EFR8374 External\Wg 585WHP
