2011 Evo Ralliart - 93oct 25psi
Old Aug 4, 2016, 02:24 AM
tscompusa's Avatar
Not sure if we can put the Ralliart in this section. Its very similar to an Evo X. it uses the same 4b11 engine. It has a different turbo, Smaller td04 and single scroll.
Mods are:
Stock block /w 90k+
stock fuel system
MAP 3.5" FMIC
3" ic pipes
Cobb 3 port
Turbo XS full exhaust /w cat
Evo X BOV
OpenSource ECU tuning /w Ecuflash
Graph and pictures below. (This is around 80whp more then stock and 130wtq more)
deylag (Nov 3, 2016)
Old Nov 2, 2016, 12:43 PM
strykr's Avatar
Those are pretty good #'s! Definitely makes me anxious to get mine tuned!
Old Nov 3, 2016, 10:44 AM
tscompusa's Avatar
We installed an Evo X turbo and put the car on E85 and made 380WHP and went 11.9 @ 118. Its made every top 3-5 list with Ralliart that I could see online as far as mph at track goes for records.
Old Nov 3, 2016, 11:00 AM
strykr's Avatar
E85 sadly isn't an option in Canada so my only option is 100+ Oct.
But if I can even get close to those numbers I'd be happy!
Did you change tires or gut the car to get an 11.9?
Old Nov 3, 2016, 05:10 PM
deylag's Avatar
I suspect not because Ralliarts weigh less than Evo Xs.
With a turbo, supporting mods, and a tune they can quickly eclipse stock Evo Xs at the drag strip.
Old Nov 5, 2016, 02:16 AM
tscompusa's Avatar
Full interior no weight reduction. I tried to get him to take seats out but he refused to.
Tires are stock size and wheels are not that light. Nothing is done to the car to save weight.
Ralliart is just like a evo X except its lighter and has SST only. Pretty awesome car.
We updated the transmission tune with super-sport from a X sst and I tuned the ECU normally.
The Ralliart tunes just like an evo X since its the same 4b11 engine That's why I put this in here.
If anyone wants to see the E70+ graph let me know ill put it here, but its in another thread also somewhere here
In the Ralliart section.
Old Nov 8, 2016, 03:57 PM
Fuego's Avatar
Please post, ralliart here also :-))
Old Apr 26, 2017, 09:39 PM
tscompusa's Avatar
This car now has a stock evo X turbo on it. It went a best of 12.08 ET this year so far and a best mph of 119-120.
Right now we are working on the clutches and getting the launch and 1-2 shift down.
We are working with another SST tuner / Beeble to get this addressed.
With a good launch and a clean 1-2 shift I think were looking at ~11.5 ET or better.
The 60ft on that 12.08 was 2.8 to put it into perspective. The car has a ton of ET in it!!!!!!
The clutches might be to shot, if so we will be upgrading soon.
The overall final goal for this customers car is to run a 10 with a larger turbo kit in the near future.
tscompusa
Evo X Dyno Results
Aug 1, 2016 07:31 AM
thawnet
Evo X Dyno Results
Oct 4, 2015 11:06 PM
CNano8
Jul 14, 2014 10:41 PM
meat_EVO
Evo X Dyno Results
32
Aug 30, 2009 05:48 PM
k2boarder3187
Jul 5, 2009 09:07 PM
Quick Reply: 2011 Evo Ralliart - 93oct 25psi
