Evo X hard drive upgrade?
I was wondering what type of hard drive the Evo X uses and if anyone has ever tried to upgrade from the 40gb unit? Search results I only found people asking the differences between 08 and 10 and about the navi.
you could maybe try imaging the 40gb disk with a program like Acronis True Image Home, then put the image onto a larger disk. Acronis has an option to put the image onto a new disk, but also increase the partition size to fit the new disk.
There is a procedure to unlock the hard drive so you can copy the contents to a new bigger hard drive.
http://www.mitsubishiforum.com/forum...ad.php?t=25583
Also, be aware that automotive hard drives are different than the normal consumer hard drives and cost more because they are able to withstand extreme heat and cold.
Acronis
You got to be a fellow IT guy ....Disc Clone that biatch and put it on a bigger drive!
I know this thread is older than sin but has anyone had any luck using an SSD and a simple image of the drive?...problem with that is it would only be formatted to the original 40gb...I believe
2K15LancerEs
Lancer Aftermarket Forced Induction Tech
Jun 23, 2017 08:47 AM
RotorGlow
Aug 21, 2009 10:55 PM
MagEvoVII
28
Jan 17, 2006 04:01 PM
