Remove cubby to tap power from cig lighter
Old Jun 9, 2011 | 09:32 AM
Mpetruzz's Avatar
that is a great thread! So it looks like i'll need to buy a bussman fuse tap and put a 15amp fuse in the first slot to keep power going to the cig lighter. Then I'll put a 10amp fuse in the other to power my Sirius unit.
I'm hoping to get this done today and will post the hopefully successful results!!!
Old Jun 9, 2011 | 09:44 AM
vastevo's Avatar
Originally Posted by TravisF
thats the one I was referring to. Look on the 3rd page to see the cleanest way (IMO) to mount this...
Old Jun 10, 2011 | 02:34 PM
Mpetruzz's Avatar
OK, so I bought the bussman tap. I put a 10 amp fuse in it because that is the max it'll handle and a 15 for the cig lighter. I plugged it in and nothing. I tried the same configuration in the radio fuse. The radio turned on fine, but no power to my Sirius unit. I tried switching the fuse positions and still nothing.
I just read an another site that in the cigarette lighter is a 5v regulator. Since I've cut the wires and am wiring it directly using the fusetap, I'm assuming that is why it's not working. If that's true what should I do??
Old Jun 10, 2011 | 05:47 PM
TravisF's Avatar
Are you connecting the ground to the bolt under the fuse box?
Old Jun 11, 2011 | 08:18 AM
Mpetruzz's Avatar
Yes, to the bolt that you see right behind the fuse box panel that you pop off.
jimbo74
Oct 4, 2016 06:19 PM
2rbolag
Sep 23, 2016 08:43 AM
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
Pbayr0lla321
May 16, 2012 09:21 AM
CrackerJackToy
Feb 8, 2008 07:47 AM
